Audiomobile MASS on the way!!!!
Old Dec 11, 2002
ChemicalBoom's Avatar
ChemicalBoom is an unknown quantity at this point
I finally ordered it after weeks of dragging my feet about what sub to buy.
I hope i'm happy with it! BTW how do you think this kind of install would sound (check pic)
i think it would look clean, but i'm not sure how it would sound.....
IM SO EXCITED!!!!!
now i need a crossover.....hmmmmm......
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] ACFDF.jpg (20 Kb)
Old Dec 11, 2002
mohawkboom's Avatar
Nice sub!!!!.... a setup like in the pic you showed sometimes doesn't work out all that well... You might lose alot of your cars natural cabin gain.I had my 2 Audiomobile EVO-R's setup like that but in a low tuned ported enclosure and it sound extremely good... sealed though I would have lost alot of low end..
what amp you gonna use on that sucker?
Old Dec 11, 2002
JBL 1200.1 (cost reasons) so i need the crossover to compensate for their sucky one
I'm still deciding on what box design i want to build. Got any cool ideas?
I already replaced the floor of my trunk with 5/8 MDF covered with vinyl. SWEET
I am probably going to cover the box in vinyl too, but I want an awesome looking install
so i am dragging my feet on what to do. ARGH!
Old Dec 11, 2002
mohawkboom's Avatar
well..you can slightly re-do your trunk and mount the sub in the spare tire well. or if both of your amps look vey similar, you can mount the sub against your seats (back of trunk) and mount the amps next to them at an angle and show them off and still have trunk space..
Also the JBL's crossovers don't exactly suck...they do their job..but they a good outboard active crossover would be better yes.. specially one with a subsonic filter and 24db/octave slope...a Phoenix Gold bass cube would be good for that...only one that pops into me head...
Are you gonna use the sub in a sealed or ported setup?...
Old Dec 11, 2002
Sealed because i've never worked with ported and therefore know nothing about it but feel
free to suggest something that u think would be beneficial
And....i'm kinda confused about the setup u mentioned....im retarded...[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Dec 11, 2002
mohawkboom's Avatar
you not retarded..I can't even understand what I'm trying to say..I need a pic..lol.
do you have a coupe or sedan?..
The MASS works optimally sealed and low end gets utterly retarded if you put it in a low tuned ported enclosure...but with the JBL's power it might bee too much if you go ported....
If you have a Sedan 1.15cu.ft sealed after sub displacent lightly packed with polyfill...
If you have a coupe .95 cubes exactly and heavily packed with polyfill..
Both would work out very flat with the respective cars cabin gain if you deaden your trunk and rear deck well
Old Dec 11, 2002
i have a sedan. i was worried about the power issue
but sealed will be just fine for me! i'm sure i'll get a decent SQ and SPL out of it.
thanks man[IMG]i/expressions/beer_yum.gif[/IMG]
Old Dec 11, 2002
BTW does that peal and seal from home depot really work or do i need some Rammat or something?
Old Dec 11, 2002
mohawkboom's Avatar
they'll handle it..Just don't try to push subs tooo hard...
Old Dec 13, 2002
WhiteRabbit's Avatar
id get a different amplifier, and in my own car, i had problems firing forward. not to say you will, but id reccommend agasint it.
Old Dec 13, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: WhiteRabbit
id get a different amplifier, and in my own car, i had problems firing forward. not to say you will, but id reccommend agasint it.[hr]
Why a different amp??
Also Peal and Seal works allright....but it's adhesive is nowhere near as good as those in Raammat, fatmat or brown bread..so it might peel and stop sealing after awhiele [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 13, 2002
LudlamTheory's Avatar
i boogie for the raindrops
im assuming he reccomends the amp due to its flaws... Xover, slew rate, etc etc... also, it may be too much power for one.. the sub is rated at 650 to my knowledge...
mo mentioned phoenix gold for Xovers, also look into audiocontrol ... i got mine on ebay for 38 bucks shipped
Old Dec 14, 2002
cause thats a sub youll hear the difference with a better amp. take an L7, itll sound the same on a jl amp as a jbl. that mass will have a night and day difference.
Old Dec 14, 2002
mohawkboom's Avatar
Okay was just wondering your reasoning behind it. Class D on an average sub on average setup can't be told apart from a good class a/b..when you get a great sub..you can tell clean off the bat
Old Dec 15, 2002
Quote
[hr]Originally posted by: mohawkboom
Okay was just wondering your reasoning behind it. Class D on an average sub on average setup can't be told apart from a good class a/b..when you get a great sub..you can tell clean off the bat[hr]
i have no idea if this is true, its just what i have experienced, which is why im reccommending a higher quality amp.
edit: might be psychoacustics, who knows [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 15, 2002
mohawkboom's Avatar
it's not...use a JBL 1200.1 or any class D amp.. then use a PPI or Arc class a/b amp (massively high slew rates) and you'll see the ddifference on high quality sub in a box with a .707 alignment
Old Dec 15, 2002
How much is one of those puppies? $$$$$$$$$$ [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Dec 16, 2002
mohawkboom's Avatar
$800+ for either one...
Old Dec 16, 2002
ebay....
also i would highly reccommend the XI series hifonics amplifier. youll never find an amp with more features. testing out a hifonics 600 watt amp at 8 ohms versus my 1200.1 at 8 ohms, SPL test only (goingby teh most important meter, my ear) the hifonics DESTROYED the 1200.1.
also the 24 db BANDPASS crossover and SEPARATE outputs for remote gain AND remote bass boost, you ahve more tunability than youll know what to do with!
you can get a 1200 watt hifonics for under 500, and they make a HUGE ssortment of various sizes!
http://www.maxxsonics.com/hifonics/amps_genxi.html
Old Dec 16, 2002
That website is annoying! [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Where can I buy them?
And BTW. Do you think buying a PG Bass Cube would be worth it? $150 Cheapest i found.
Old Dec 17, 2002
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
If your looking for a PPI amp, I'll sell you mine. Its a PCX1500, 1000 watts RMS at 2ohms. Retails for $1199, but it has a couple scratches on the top of it. I'd let it go for $450. Its about 4 months old.
Old Dec 18, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: custom2k1
If your looking for a PPI amp, I'll sell you mine. Its a PCX1500, 1000 watts RMS at 2ohms. Retails for $1199, but it has a couple scratches on the top of it. I'd let it go for $450. Its about 4 months old.[hr]
Damn..that is a good deal [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
michael0219
Sep 1, 2015 10:25 PM
weedo
16
Oct 8, 2004 11:56 PM
RSX XTC
May 6, 2003 04:27 PM
impetigo
Oct 23, 2002 02:48 PM
Player1
Mar 20, 2002 01:36 PM
