Sub Question
Old Sep 30, 2002
blk2k2civic's Avatar
Banned For My Beliefs
blk2k2civic is an unknown quantity at this point
Sub Question
I know absolutely nothing about car audio, so forgive me if this sounds stupid. I was talking to a friend (Who sells audio) and he was trying to sell me some subs. I got a pretty good deal for 2 12" Type R w/box but he said the amp to run it was $$$$. The bottome line, he says that Underpowering a sub is way worse than overpowering it? Is that true? Or does overpowering it lead to less sub life?
Old Sep 30, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
overpowering it will cause more more heat, if you go beond (Sp???) the thermal limit it will blow the sub
underpowering a sub, will cause less volume so you will turn it up more, when you turn it up more you will start to cause distortion which will blow your sub
most of the time your are underpowering your sub when turning up your stereo you make more power.
dont know if you understood what i just said cant figure out how else to explain it.
Old Sep 30, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
I always go with the rule of thumb of overpowering. Underpowering is not a good thing, and most people don't know when to stop with underpowered subs.
Old Sep 30, 2002
mohawkboom's Avatar
What Ohm load configuration are those subs?..
Underpowering isn't bad is you don't drive the amps into distortion. Overpowering can melt the VC's.. Keep in mind that most subs are rated using Sine waves which is a constant output wave. Music is not constant output so for music subs can genrally take about 25-33% more power than they are rated for...
Pending the ohm loads of those subs..there' a few inexpensive good amps that will push them with authority..
Old Sep 30, 2002
thanks alot for your comments guys
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
