LPF On Amp
Old Sep 30, 2002
ROBREALZCIVIC's Avatar
ROBREALZCIVIC is an unknown quantity at this point
LPF On Amp
I got a quick question for anybody who can help. I have A Sony CD Head Unit and It Has a 125 Hz LPF(Low Pass Filter) on it. Should I use it in conjuction with the 80 Hz LPF on My AMp . What would The Diffrences be?
Old Sep 30, 2002
mohawkboom's Avatar
Won't make a difference...just use the LPF on the amp..
Old Sep 30, 2002
Litespeed's Avatar
Litespeed is an unknown quantity at this point
If you have the LPF on the amp set lower than the LPF on the HU then the LPF on the HU won't do anything. If it was the other way around then you could adjust the LPF using the HU instead of using your amp. It's a matter of convenience.
Old Oct 1, 2002
Abstract's Avatar
Abstract is an unknown quantity at this point
Wrong it will affect it, you will end up having a larger slope. If one os 18db per octave and the othr is 18dc per octave you will end up having an 80hz corssover poitn at 36 db per ocatve, but you will have a 18 db per ocatve gap between 80-125, I would leave both on, provided you have your mids running at 80Hz and above not 125, or esle you will be missing alot of mid bass.
Old Oct 1, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
Abstract is correct. It will act as a cascading crossover. It won't hurt you to leave both of them on.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
