SUB Problems
Old Sep 16, 2002
badcivic2002's Avatar
badcivic2002 is an unknown quantity at this point
SUB Problems
I removed my Hu to paint my center compartment. When I went to hook everything back up all of my speakers worked great but nada from my subs... So I took it back out and checked the connections, and all were made correctly and tight. I can feel the subs just BARELY moving when the music plays if I touch them.
Any help would be appreciated.
Thanks
Old Sep 16, 2002
Regularjoe's Avatar
Regularjoe is on a distinguished road
What kind of subs, amp, etc .....
If the Subs are dual voice coil make sure one coil isn't wired backwards.
If one coil is pushing and the other is pulling nothing happens even though everything is correct.
push + push = bass, bass, bass
push + pull = no bass at all even at full volume
Good luck ....
Old Sep 16, 2002
I am using PPI Pc1400 and 2 Image Dynamic IDQ12
But... I did not change any of the wireing. The only thing that I did was remove the hu and center plastic piece. Before I did this they were working fine but now nada.
Old Sep 16, 2002
Ed's Avatar
Ed
Maybe some settings on the player changed? did you remove the power on the car?
Old Sep 16, 2002
Nope, already checked that... I did notice that my fuse box for the stereo is pretty messed up so I am going to get a new one and check the fuse.
Old Sep 16, 2002
WhiteRabbit's Avatar
forgot an RCA cable maybe?
Old Sep 17, 2002
Samson's Avatar
Samson is an unknown quantity at this point
yeah i think id check and make sure both left and right are hooked up
Old Sep 18, 2002
Ok, thanks for the help... I found it. It was just the remote wire was loose.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
