resistance
Old Sep 6, 2002
Gizmo's Avatar
Gizmo is an unknown quantity at this point
resistance
Im trying to figure out why my sub/amp does not seem to work. I was wondering if I could use a voltometer and check the resitance and see if that tells me anything. I tried it on the amp and there is no resistance (like no connection). But im not really sure if thats much help. Anyone have any ideas on whether I can tell if a sub is dead or amp other than using another sub or amp (which I dont really have ready access to)?
Old Sep 7, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
i had a similar problem, check at the terminals on the sub, or box, and if you have power and theres no sound, its the sub, thats what happened to me, and luckily my sub was under warranty, so i got a news one, if theres no power at the sub, its the amp. hope that helps.
Old Sep 7, 2002
tbone323's Avatar
tbone323 is an unknown quantity at this point
measure the impedance of your subs...the meter should read around 4 ohms (per voice coil) If its too low, you may have fried your voice coil and, in turn, possibly caused damage to your amp. If you have no other speaker to k=hook up to your amp to test, put the amp on V(ac) across the speaker terminals and play music, if the voltage changes, you have signal at the outputs, if the meter shows nothing, your amp needs fixin.
~Tbone
Old Sep 7, 2002
Gizmo's Avatar
Found out that the little metal tinsel lead thing on the sub fried off so that was the problems
Old Sep 7, 2002
yeah man, thats what happened to me, somethin like that, i didnt actually see it, but he said i melted somethin to the cone, voice coil?
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
General DIY
Sep 25, 2015 08:02 PM
PunX
Sep 23, 2015 10:45 PM
Bruce2
Sep 21, 2015 08:01 PM
