Share space?
Old Aug 29, 2002
CivicRiderCA's Avatar
CivicRiderCA is an unknown quantity at this point
Share space?
This may be a dumb question, but is it bad for two or more subs to share air space? meaning can one cavity serve two enclosed subs? will this cause problems? Just curious, it seems like multiple sub installs would be quite a bit easier if airspace could be shared.
Thanks!
Old Aug 29, 2002
mohawkboom's Avatar
This debate is worse than the Capacitor one... there are no distinct advantages or disadvantages as far as sound goes. The only time sealed chamber setups are more useful is if one sub blows..then the other still has the proper airspace.
Also the divider in a sealed chamber is a great brace...but a properly braced common chamber enclosure will sound the same provided all equipment is working fine.
Old Aug 29, 2002
juscallmetoyota's Avatar
juscallmetoyota is an unknown quantity at this point
I don't know too much about car audio but from the systems I've heard before, the sealed closures seemed to sound more direct vs. the ones sharing air space.
Steve
Old Aug 30, 2002
Maybe i wasnt making myself clear (?) I mean two subs using a single sealed enclosure....I think you understood, mohawk, cause your answer makes sense, i just wanted to make MYSELF clear.
And a followup question: so if two subs are sharing a single sealed enclosure, is the chance of one or both of the subs blowing any easier increased?
Old Aug 30, 2002
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
toyota - Define "more direct"
Old Aug 30, 2002
Quote
[hr]Originally posted by: JohnDoe
toyota - Define "more direct"[hr]
I mean like more "crisp" sounding.
Old Sep 2, 2002
You all seem to have missed my clarification and second question. I don't mean free air subs, i mean two equal subs sharing a single sealed enclosure, thats all.
Old Sep 3, 2002
mohawkboom's Avatar
Given the enclosure is properly braced there should be no difference in sound..or risk of blosing the subs ina shared chamber enclosure. Running 3 or more subs shared chamber though causes rear wave cancellation and causes subs to perform rather oddly sound wise.. Shared chamber for 2 subs.. FIne..no problem.. Shared Chamber with 3+ SUbs...no..
Cheers
Mohwk
Old Sep 5, 2002
WhiteRabbit's Avatar
Quote
[hr]Originally posted by: mohawkboom
Running 3 or more subs shared chamber though causes rear wave cancellation and causes subs to perform rather oddly sound wise.. [hr]
how do you figure that?
Old Sep 5, 2002
mohawkboom's Avatar
Phasing problems between the 2 subs at the ends. The sound waves travel far and cause rear wave disruption..
Old Sep 6, 2002
waves are WAY too big for that to be a problem. its more along the lines of diminishing returns, not phazing issues.
but if your really that worried about it, you can install all woofers using the line source theory, installing the woofers in an arc designed so that each pathlength from each woofer is the same distance to the ideal listening position. that will fix that issue right there......
Old Sep 6, 2002
LudlamTheory's Avatar
i boogie for the raindrops
an even better way to fix the issue would be to create separate chambers... but we've already discussed that one =)
Old Sep 6, 2002
nope, seperate chambers wont fix phazing issues addressed by mo. installation in a line will tho. regardless of seperate or shared air.
again, your not looking at "canncellations" you are looking at "diminishing returns".
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
ttamrekab
Sep 25, 2015 04:41 PM
