tweeters are too big
Old Aug 9, 2002
ctducs's Avatar
ctducs is an unknown quantity at this point
I was just given a pair of MBQuart CM2216CX. The tweeters are too big for the pod in my '02 coupe EX. Any advice on what to do. Maybe I should just install the 6.5" and leave the factory tweeters.
Old Aug 9, 2002
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
You can always file the hole to match your tweeter. Do a little DIY mod. Or you can keep the stock tweeter, up to you
Old Aug 9, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
I had that exact problem when I bought MB Quart speakers. I asked the shop if they can modify my tweeter pods but they said to just exchange it to the next line of speakers. I did just that and the tweeters fit perfectly in the pods. I have the QM 218.03 CX speakers. If you want to, you can sell your speakers and use that money to buy speakers that fit.
Old Aug 10, 2002
VNlilMAN's Avatar
The Standard One
you could sell it to me [IMG]i/expressions/face-icon-small-smile.gif[/IMG] i'm in so cal too... but if not i would just sand out the hole till it fits, either that or just get new tweeters. i dont even have pods so i'm going to have to drill a hole for the tweets.
Old Aug 10, 2002
dnutz's Avatar
dnutz is an unknown quantity at this point
I'm sure you can find someone w/o tweeter pods that will trade you their blank piece. Then use there blanks and mount your tweeter custom on that. Gives it a good look with the doors shut.. just my .02
Old Aug 10, 2002
ctducs's Avatar
Thanks for the suggestions. I installed the 6.5's and left the factory tweeters in there. I think I'm gonna buy new components that fit when I start getting my discount at Circuit City. Those 6.5's were a pain to install. It took me more then half the day to install them. I bought 1" spacers but the speaker wouldn't even fit through them so I had to get some MDF and cut my own spacers. Does anyone have a suggestion on a component from Circuit City to replace the MBQuarts with. Will the 5.25" Alpines fit? When I was in the store I think the only ones I saw with tweeters small enough to fit the tweeter pod were the Infinity's.
Old Aug 10, 2002
JJF's Avatar
JJF
JJF is an unknown quantity at this point
ctducs- I have rockford components that are an oversized 6 1/2, actually it's a 6 3/4, take your 1" spacer and a dremel and grind about 1/4" at a 45 degree angle. This should give the speaker basket enough clearance. I would also recommend that you use some type of sound deadening material as well...Good Luck
Old Aug 10, 2002
bullitt's Avatar
bullitt is an unknown quantity at this point
With minimal fialing or the use of a dremmel tool the larger tweeter's fit perfectly and can actually make those ugly pods look better. It would be more preferable to have them closer to the speaker if you have the blank pods and are good at cutting your door to mount the tweeter to get better optimum sound. Anything can be done to a Honda!
Old Aug 10, 2002
tom1178's Avatar
tom1178 is an unknown quantity at this point
I've got the MB Quart PSD 216, the tweeters fit in the factory pod, you just have to get a long enough screw and washers to make it fit tightly, it'll be slightly oversized but it's better than buying something else
ricer_em2
May 11, 2016 08:09 PM
Tedverseti
Sep 29, 2015 05:41 PM
anubis62
Sep 27, 2015 12:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
ZoSoIV
Sep 17, 2015 07:17 PM
