'02 LX speaker sizes? (Repost from General Section)
Old Aug 7, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Searched and found this for the EX:
Front 6.5
Back 6x9
True for LX, too?
And finally, any recommendations? I'm looking to spend under $100 for each pair.
I need something that will be able to handle subs....and high volume.
Old Aug 7, 2002
mohawkboom's Avatar
ALL Coupes use 6.5's in front 6x9's in back.. ALL sedans use 6.5's in front 6.5's in back
Old Aug 7, 2002
slim6294's Avatar
slim6294 is an unknown quantity at this point
Do you know if it is the same for 2001 Civics as well?
6.5 for sedans? or is it 5-1/4?
thanks!
Old Aug 7, 2002
mohawkboom's Avatar
it's the same for ALL 7th gen civics.... 5 1/4" will fit in front no problem.. 7" will fit the rear no problem. for sedans.
For coupes.. 5.25's can fit the fronts
Old Aug 7, 2002
slim6294's Avatar
ok, i'm a little bit confused, so if i want to replace my rear speakers on my 2001 sedan (left one is blown in fact, or semi-blown),
then i should get 7"s? or stick with 5-1/4 for that too? I did look at them and they look like 5-1/4, 5 1/2s. The 6.5 seemed reasonalbe.
Just curious what the stock size is. I can't believe that no website or not even the owners manual lists this information. Thanks!
Old Aug 7, 2002
VNlilMAN's Avatar
The Standard One
slim6294, you should get the size you already have in your car. which would be 6.5s all around. he is just saying that you could get 7" or 5 1/4 if you wanted to.
as for recommendations... maybe like the top of the line pioneer 3ways. well atleast thats good enough for me... but then my friend just got mbquartz and those things sound nice so i'm kinda thinking of spending more and getting those.
btw, since you said you wanted them to handle alot, i'm guessing your going to run them with an amp, whats your budget for that?
Old Aug 7, 2002
slim6294's Avatar
already got one off ebay, its decent, 800W 2-chan, way more than I need.
a friend of mine just showed me a decent deal on some subs, so i think i'll get that
and we're hooking in the stuff next week along w/ my pioneer headunit.
might still get some new speakers for the rear in the future...
Old Aug 7, 2002
ak's Avatar
ak
Retired Mod
I'm going with Pioneers, all 4 speakers....plus some cheap tweeters. Later on i'll get some subs... 2 12" JL's, or 2 10" Rockford Fosgate... Not sure yet
Old Aug 7, 2002
mohawkboom's Avatar
The rear hole cutoutrs match the sizing for a European 6 3/4" Speaker.. some 6.5's don;t fit properly in the rear.. a 5.25 might fit right through the hole... for the front ither 5.25's or 6.5's can be used
Old Aug 7, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: ak
I'm going with Pioneers, all 4 speakers....plus some cheap tweeters. Later on i'll get some subs... 2 12" JL's, or 2 10" Rockford Fosgate... Not sure yet[hr]
Cheap tweeters.. cheap tweeters are not good.. THey are generally VERY harsh sounding, and have crappy crossovers.. They tend to break up and distort quite noticably... if you want a god inexpensive tweet..look into Vifa [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
Old Aug 7, 2002
ak's Avatar
ak
Retired Mod
how about rockford fosgate tweeters? uh...i placed a bid on this Lexon Tweeters.. winning 11 cents! I'd retract it, but it's ending soon...and blah.. maybe i'll buy them and resell them.. who knows.
Old Aug 7, 2002
mohawkboom's Avatar
Why get tweeters though...why not save up a wee bit and get component speakers?? for $130 at sounddomain.com you can get a very nice set of Crystal Mobilesound components.
Old Aug 7, 2002
VNlilMAN's Avatar
The Standard One
or the cheap mbquartz for 150.
Old Aug 7, 2002
mohawkboom's Avatar
Quote
[hr]Originally posted by: VNlilMAN
or the cheap mbquartz for 150.[hr]
Those severely lack anything resembling midbass though...
Old Aug 7, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
you want speakers that sound good right. so when you get your new speakes and you go cheap and you turn them up and blow them and get confussed just turn around and kick yourself. take the time now to do your system once and do it right. you'll spend so much more money on cheap stuff cause you'll be buying something new in a few months. a good set of of 6.5's up front with anywhere from 50-100 watts should be fine and don't even bother with the rears just unplug them. its well worth it and then you only have to tear apart your car once. and don't forget the first time you do your car prewire it for everything you ever plan on doing cause the more your tear it apart the more chances to mess stuff up. wire's are generally cheap so get them all there.
Old Aug 8, 2002
Vinas's Avatar
Vinas is an unknown quantity at this point
Whats exactly are components anyway? Pros/Cons over the alternatives?
Old Aug 8, 2002
mohawkboom's Avatar
Components are a woofer, a crossover network and a tweeter. in general. The woofer is sealed..has no attached tweeter. The set somes with a Low pass crossover for the woofer and a highpass for the tweeter. Component sets generally offer better midrage sound..more midbass. Cleaner high frequency sound. There's some cheap components that are junk..and there are some co-xials that are great..but Component speaker systems give you more options for tweeter mounting locations adn the like.
Cheers
Mohawk
Old Aug 8, 2002
Vinas's Avatar
So I've got a 01 LX coupe, stock everything, but with a RF 250.2 bridged powering a 12" Infinity perfect. I happen to be running off an older Panasonic HU, CQ-DF44... no Sub-out or anything, its pretty basic. 40w x 4 listed as the output.
What would you recommend for crisper, louder, music? As it is, the sub is pretty clean, but the stock speakers peak out at fairly low volume.
Old Aug 8, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]Originally posted by: Vinas
40w x 4 listed as the output.[hr]
i'm thinking thats peak? i think most headunits are 22 x 4 RMS. if so you might want to invest in an amp
Old Aug 8, 2002
ak's Avatar
ak
Retired Mod
All right, i won auctions.....too many speakers to choose from on the market......tsuitgjpaosyjapoi
Front
Rear
Old Aug 8, 2002
mohawkboom's Avatar
Congrats you spent $5 more than their worth with the shipping tacked on...their $63 at woofers etc. for the fronts
saved $30 on the 6X9's though.. dude always shop around alot before ya buy stuff.. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
thaler4cuse
Sep 7, 2015 08:25 PM
redcloud
Sep 7, 2015 01:45 PM
KikAzz
Sep 4, 2015 12:36 PM
jpat21
Sep 3, 2015 11:32 PM
