attn all: do i need a bigger alternator?
Unless your running a 1000Watt + High Current amp..and like cranking your music to the max 24/7..
If you keep your listening level within reason you'll nnever have to worry about it....My system with my 1300Wrms of class a/b Power drawas 32amps at a nice loud and clean listening level..which is more than most can take because I'm 40% deaf to begin with. ... At full power..my amps draw 84 amps playing a 50hz and 1khz sine wave ... with Music the biggest amperage draw I've had was a 52 amp average playing 976-BASS (on a calibrated termpro mic hitting 147db's)...peaked a little over 90amps though.
So to answer your questions. If you want to run a big system..ps/2 Neons.. yes an alternator upgrade is highly reccomended. If your running a pretty big system with a class D amp for your subs..you may elect to get a capcitor if you have dimming but a new alternator would not be necessary.
I went the overkill route...but then again on occasion I hook up my 600 watt power converter and and host tailgate parties out of my car..with music..a few portable floodlights and a electric cooler [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..
Quote
[hr]Originally posted by: mohawkboom
Unless your running a 1000Watt + High Current amp..and like cranking your music to the max 24/7..[hr]
but if you dont know to the point whre you are on here asking, the answer is no.
What alternator did you put in your ride mohawk?
when I am finished I am going to be running a pretty big system, neons, dvd, sounds...
so just curious to see how much they run and what brands..
-Michael
-Michael
Yo....
I would love to hear what alternator was installed??? I 'm close since my system draws the alternator right down at IDLE so I think I should do sumptin about it. The systems uses about 25 to 30 amps in peaks. Our factory alternator is only 70 amps at 30 volts to begin with and with my system and AC running it is around 12volts at idle from the alternator. Its close but I'm sure I should get sumptin since my system is only going to get better and need more power!!!
[IMG]i/expressions/face-icon-small-smile.gif[/IMG] [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
l8r
darkside420
l8r
darkside420
My old alternator put out 14.1 volts at idle..but voltage dropped a fair bit with all accessories on.. at idle..the alternator generally won't charge...there's not much that can be done about this. If the dimming bothers you..get a capacitor...otherwise..it;s nothing to worry about. If your driving at highway speeds and your lights dim and your car slows down 2-3MPH..then your drawing far too much current lol.. And yes..you can use your alternator as an engine brake [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
As for my alternator..it's an Ohio Generator 160amp hot rated alternator with external regular bought from ampmanaudio.com cost was $670US+shipping. 1 year warranty. Comes with all parts needed took me 3 hours to install...(I'm a certified mechanic) never worked as one though. If I had a lift it would have took an hour and a half.
Cheers
Mohawk
Cheers
Mohawk
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
260000milesgoal
Sep 25, 2015 07:41 PM
