please help with amp problem
Old Jul 16, 2002
SkiLLzSter's Avatar
illest ma f*cken member
ok i have a fosgate 500.2 amp running a 12 inch JL W3 D4...the problem is when i tap the amp like knock it or shake it a little the bass stops hitting but the power and everything is fine...nothing is wrong...and you know when the music plays and bass hits it vibrates right so when it vibrates too much the bass cuts off and when it cuts off and starts to bump again it stops when it vibrates so i'm getting very choppy bass hits...so i'm assuming its the amp problem because when i tap the amp and shake it a little it stops the bass...when i play the music lower like not bump it as hard it doesn't cut off only cuts off when i play it high like when the bass vibrates really hard...its weird...had the amp and subs for like 8 months or so and never had a problem until just recently out of no where a problem like this comes up...i'm in the processing in figuring it out but can't so i need your help thanks in advance....
Old Jul 16, 2002
mohawkboom's Avatar
Sounds like the bord is cracked..or somethings loose..find a shop that does amp repairs..should be an easy fix
Old Jul 17, 2002
SkiLLzSter's Avatar
aww man...how much does it usually cost??
Old Jul 17, 2002
mohawkboom's Avatar
Depends...shoudn't be more than $50 at the very most.. most likely $25 ish.. might just need some hot glue
Old Jul 23, 2002
SkiLLzSter's Avatar
new findings in the problem...when its cool i can tap it, knock it or even bump it max it won't stop the bass, i haven't had the time to get it fixed yet...
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
