some input please...
Old Jul 9, 2002
NAcoma's Avatar
NAcoma is an unknown quantity at this point
i just came across another bit of money for me to waste..i was thinkin of gettin these components to form the stepping-stone of what is to be my first setup.
as i jus said im new to installing audio equipment so lemme know what you think of this stuff...
Audiobahn: AW1208Q Flame Compression 12" Subs
ABV125Q Dual 12" Ported Box
ABC525Q 5.25" Speaker System
AEX350X 30-Band Equalizer Crossover/Line Driver
OZ Audio: Delta 2400 2400w Mono Class D Amplifier
HiFonics: Andromeda 125XIV 600w 4-Channel Amplifier
This is all im gettin for now cuz this will pretty much completely deplete my recent umph of money. Any other suggestions or recommendations will be appreciated.
peace
Old Jul 10, 2002
mohawkboom's Avatar
Spend the money much more wisely dude.. MUCH more wisely..
Old Jul 10, 2002
NAcoma's Avatar
like i said i was jus thinkin.. what do you think would be better? last time i heard the flames at a car show they sounded pretty good.
lemme know
peace
Old Jul 10, 2002
mohawkboom's Avatar
Depends..if you want an all audiobahn setup..or wouldn't mind mix-n-matching a whole system..Also do you plan on competing in SQ with your car?..or SPL?.. or is it just to bump around with?..also if you want to run HUGE power.an extra battery and H/O Alternator would be in order...
Old Jul 10, 2002
NAcoma's Avatar
yea i was gonna get an extra battery..as for the sq vs. riding question: how far do you think i could go with this stuff?? if it couldnt get me a high spot then ill prolly jus cruise around..
peace
Old Jul 10, 2002
mohawkboom's Avatar
Extra battery is a bad thing..Unless you upgrade your alternator as well.
Cheapest alt so far for our cars I've seen is $670 for a 160 amp alternator..Which is the one I have. Tis good..it can supply juice for 1300wrms of class a/b Power, A/C and all accessories on and never drop below 13.4 volts...
With your apparent budget I'd look past audiobahnsubs to maybe something that would sound quite a bit better. And save your$$ on the Oz Audio Delta amp and buy a pair of amps for the subs [IMG]i/expressions/face-icon-small-smile.gif[/IMG].
Going witht he costs of wha you posted so far. you can buy 2 Arc Audio 1500D-R's a pair of Arc Audio 2150CXL-R's Some Rainbow Pro series components and a pair of IDMAX's [IMG]i/expressions/face-icon-small-smile.gif[/IMG]...and bump insanely and sound phenominal
Old Jul 10, 2002
NAcoma's Avatar
ill look into those..thanx
Old Jul 10, 2002
mohawkboom's Avatar
Ampmanaudio.com
It may not be the "best" You can get...but it's precisely what I would do/am doing ..I have the rainbows. I'm down 1 Arc1500D-r I have 2 IDMAX D2's. Rainbow Pro's. Arc 2150CXL-R. 2 Audiocontrol EQT's a H/O Alternator. No extra battery...and an Eclipse 5441 (used to have an 8051 but the output voltage was aproblem with Arc Amps which put out max power with a 2.7 volt signal [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
Luluharp
Sep 27, 2015 11:56 AM
speedlever
Sep 24, 2015 07:18 PM
chiquita.banana
Sep 24, 2015 09:42 AM
JMKendrick
Sep 16, 2015 06:17 PM
tomas6791
Sep 11, 2015 06:47 PM
