Back seat amp install, need ideas
Old Jul 7, 2002
white97ex's Avatar
white97ex is an unknown quantity at this point
Im going to install my amp into the backside of my back seats. I want to basically cut a hole where the metal is on the back, then create a type of box that will fit in there flush, about 3" deep...then put a piece of plexi-glass with the PPI logo cut out on top of that.
After thats done put all of it back together, and cut a hole in the fabric on the backside of the seat so you can see through to the amp.
Im wondering if anyone has done or seen a install like this and could help me out on some do's and dont's of it. My amp is 17" long by 10" wide bye 3" high.
Old Jul 7, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
17" huh? My MTX was 14", you should make sure it will fit the opening with the seat back before you start working on it.
Old Jul 7, 2002
white97ex's Avatar
it will fit, i already have the seats out and measured. just would like an actual picture of a few installs like this.
Old Jul 8, 2002
white97ex's Avatar
well i figured out how to do it using sheet metal...im going to take pics and make a DIY since this is prob gonna take a little time ..but its gonna look sweet as hell when im done [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 9, 2002
DxMaN's Avatar
DxMaN is an unknown quantity at this point
Well, one don't comes to my mind...heat. You need to come up with a way to vent the boxes or better heatsink your amps (e.g. mount them on some metal). Depending on how much power you run, and how much you drive your amps, that little compartment could turn into an oven. You'd probably experience alot of cutouts as the amp turns off from overheating, or worse, you could possibly burn it out.
I'd look into some 12v computer fans for air circualtion. You could cut some type of tube into the seat with the fan inside bringing in cool air, but I can imagine that to be a logistical nightmare.
Old Jul 24, 2002
Bdubb's Avatar
Bdubb is an unknown quantity at this point
how is it going to cool off?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
mistermenphis22
Apr 3, 2016 08:06 AM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
twtron
Apr 17, 2015 12:09 AM
JeffSpeed21
Nov 3, 2001 10:32 AM
