Max boom for current setup...
Old Jun 19, 2002
SilverSurf's Avatar
SilverSurf is an unknown quantity at this point
Ok Mohawk or WhiteRabbit, or any other ICE gurus, long thread please bear with me.
Here's the deal. Currently I have an MTX 8302 2-ch amp pushing 2 MTX 6000 subs (250 RMS/500 max watts each), both subs are 4 ohms each. Right now each sub is wired in stereo to each channel, presenting a 4 ohm load to the amp. (I assume). Well I was going to parallel wire the subs and wire them bridged to the amp, presenting a 2 ohm load to the amp (I think), except that the amp requires a minimum 4 ohm load bridged. It is 2 ohm stable, but only in stereo, so I assume I would have to have 2 ohm subs and wire them in stereo to each channel to get the 2ohm load and higher output, or get 2 8 ohm subs, wire them in parallel for a 4 ohm load. From my estimates I am getting about 150 watts RMS per ch. to each sub. Several questions, I know it is not recommended presenting a 2ohm load bridged to my amp requiring 4 ohm minimum bridged, but what type of damage can happen? Will it play for a while and then cut out? With my current components, what is the best wiring scheme for max bass response? I can swap out the current amp for a Kenwood KAC-728s if it is better. What's the recommendation? Thanks for the input guys. [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Jun 19, 2002
mohawkboom's Avatar
Well,
Unless you get the 8ohm or DVC 4 hm version of those subs..you can't run it bridged. Your amp will overheat and blow a capacitor or fry some transistors..which is not good.
Old Jun 20, 2002
WhiteRabbit's Avatar
unless it has protection, like my old JBL amp, or fuses that will blow first, like any earthquake.
Old Jun 20, 2002
WhiteCivic's Avatar
WhiteCivic is an unknown quantity at this point
It will work even though your amp is not 2ohm MONO stable. But like Rabbit and Mohawk said...its not worth the risk of frying your amp...which it will in time... I would just buy 2 DVC 4ohm subs (wire them in parallel) and then you can present a 2ohm load to each channel. or if you have the room..buy 2 more 4 ohm subs and you can get a 2ohm stereo load....and you will have FOUR subs...which is worth somewhere around 2-3db's running multiple subs. That is what I did.
sf3r8z
Apr 19, 2016 01:53 PM
General DIY
Sep 25, 2015 08:02 PM
Skunkone
Sep 24, 2015 04:38 PM
krazykoncepts
Sep 8, 2015 09:02 PM
jpat21
Sep 3, 2015 11:32 PM
