my video idea...suggestions?
Old Jun 19, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
i found a sharper image brand 5.6" lcd screen on ebay for $96, it doesn't look like theres anything wrong with that deal. now check this. it mounts on like a little stand. Also, my cd player has audio in jacks. So....
#1 - fabricate plastic/fiberglass piece to go over cupholders to mount the screen to, run wire back behind cupholders through that slit.
#2 - mount ps2 somewhere, run video out to this screen, run audio outs to cd player aux., and power the ps2 w/ the power inverter and the cigarette lighter (or better yet, straight wire it to the battery)
whatcha think?
eric
Old Jun 19, 2002
mohawkboom's Avatar
SOunds about right..
Old Jun 20, 2002
MistaFreeze's Avatar
MistaFreeze is an unknown quantity at this point
thats what im doin. are you building the screen into the dash?
Old Jun 20, 2002
WhiteRabbit's Avatar
make sure you can get power and a signal to that lcd. two things you want to look at...
signal source? is it RCA? s-video? if it is, you are set.
power source? is it 12 volts? that will make it easier, if not, you will have to do some odd tricks to get power to it. furthermore, if it IS 12 volt, does it need a regulated supply? your car will put out from 12 to over 14 volts in given conditions, thats ok for this screen? if not you will have to do more fancy work to get your LCD power.
do you plan to run your ps2 off an AC converter? if so, you have a POSSIBLE solution, no matter what voltage your lcd requires. cell phones and discmen all come with power supplies, from around a volt or even less to 24 volts or even higher. all run off AC power. lets say your LCD in fact runs off 4.5 volts of power. thats fine! you can get a power dealy for a cd player (most are 4.5 or 6 volts) and hack it to get the wires to plug in. theres yoru power problem solved. (I am not taking into account regulated power, I hope the ac inverter can do that job)
hope this is useful in some sort of way.....
Old Jul 28, 2002
Marcivic3303's Avatar
Marcivic3303 is an unknown quantity at this point
Look what I Did, i just cut a whole in that piece right above the cup holders where the cig. lighter is.. and made my 5.6 screen there, then all I did was Carbon Fiber the whole piece including the screen look..
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] screen6565.jpg (97 Kb)
Old Jul 28, 2002
real carbon? and can you take a closer pic? i wanna see that carbon job.
you did very nice mold work, i must admit. i like it alot.
that kind of skill goes very far in the audio industry... [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jul 30, 2002
Bryn's Avatar
Bryn is an unknown quantity at this point
no, it's not real carbon. He mentioned in his post about how he did it that he bought some carbon fiber look alike paper from EBay, and stuck it on! Not quite the same skill required as real carbon, but it still looks pretty good. Shifters in the way, but oh well!
Old Jul 30, 2002
;_;
Old Jul 30, 2002
Its just Carbon Fiber Sticker crap off of ebay for like $15 it did a great job, covered up alot of crap, and matches my Carbon Fiber Dash Kit, so it looks half way factory.. Its not paper.. Thanks for the comments, and really the Shift isnt in the way taht much for the ppl in front cuz you get a side angle on it, and in the back ppl just have to sit up to see it.. its not a big problem at all, my friens love it... thanks again!
Old Jul 31, 2002
beamer's Avatar
beamer is an unknown quantity at this point
How big of a screen can I put in dash.
Old Jul 31, 2002
as big as you want to.
how big of an engine do you wanna stick in yoru car?
Zygrene
Mar 22, 2016 12:36 PM
Hutch1051
Sep 29, 2015 09:20 AM
carid
Sep 28, 2015 10:13 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
tomas6791
Sep 11, 2015 06:47 PM
