I need help with head unit installion
2 questions. I have a Kenwood deck and I am using the schosche HA08 connector. First, the HA08 has 2 orange wires, one for the illumination and one for the dimmer, but the kenwood harness only has 1 orange wire for the illumination. Do I only connect the illumination wires and forget about the dimmer wire on the HA08, or connect all three orange wires together? Lastly, the kenwood harness has 2 blue wires labeled "P. CONT" and "ANT CONT" but the HA08 has no blue wires, so I guess the blue wires don't connect to anything right? Thanks.
Just hook up the illum wire, leave the dimmer wire alone, because your HU doesn't use it. The blue 'ANT' wire is for a power antenna, or you can hook it up to your amp(s) remote wire so that the amp(s) turn on/off with your HU.
Hope this helps.
