WTF!? My PS2 making my car sound turboed!? Help!
Old Jun 12, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
I finished my PS2 install last night and finally picked up the memory card today so I could run the DVD player in it. Everthing's up and running, but somethings up with the install on the headunit. I have the Sony Xplod CDX 750A (pretty sure thats the #) and I had to buy an adaptor in order to get sound into the headunit...something to do with the bus input or something. I've checked the connections and everyhting seems fine, but I'm getting this horrible pre-amp buzzy type sound whenever I put the headunit on CD-AUX1 to get the ps2 sound. And everything I accelerate, my car starts to whine just like a supercharger but it honestly behaves in the exact way a turbo sounds. What the hell is going on and how do I get rid of the horrible buzzing when the car idles!?
Old Jun 12, 2002
mohawkboom's Avatar
It's the power inverter you used. Run your RCA's as far away from the inverter as possible.....
Old Jun 12, 2002
makes sesnse...the only place i found for the inverter was zip-tied above my golvebox so everythings within a foot of eachother. thanks!
Old Jun 12, 2002
EvilTwin's Avatar
EvilTwin is an unknown quantity at this point
I know what you mean...I have the same problem. I'm guessing alot of people who install a ps2 have the same problem.
Old Jun 14, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
Couldn't u also use a noise filter
Old Jun 14, 2002
mohawkboom's Avatar
Nope....not really.. the noise is caused my electromagnetic inferance.. not a grounding loop...Just use good RCA's and keep the RCA's as far away from the inverter and ppower wire as possible.
Old Jun 16, 2002
Perfikt8's Avatar
Perfikt8 is an unknown quantity at this point
Hey all. i have the 650 model of this sony deck, and i have a question about the "bus input." can i run the AUDIO OUT from my laptop into this "bus input?" and would i need this inverter you all are talking about? if so, where do i get one, radio shack? thanks all dave
Old Jun 16, 2002
VNlilMAN's Avatar
The Standard One
had the same problem with my friends tahoe, n yes its most likely the power inverter... he had his running directly from the bat and it made the noise, now he has one where you hook it up to the cig lighter n theres no noise... try powering the ps2 using an extension cord to your house, if the noise its gone you know its your inverter
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ashleymmackey
Apr 18, 2015 09:48 PM
ej8
Apr 13, 2015 06:36 PM
01civicboi
Bolt-on Engine Performance
Nov 2, 2001 07:33 AM
