!!HELP!! Please ASAP!
Old Jun 9, 2002
scrible's Avatar
scrible is an unknown quantity at this point
I just got my Alpine 7894 CD Player 2 days ago from Onlinecarstereo.com, I installed it it worked fine then today I went and bought some temporary speakers for the front and rear to replace my factory speakers, I bought 2 jensen 3-way 61/2's for the back and 2 jensen 2way 61/2's for the front once I hooked the back up I got the radio up to about 24 volume and everything just shut off (the radio, and the digital clock on the dash) no power, no nothing so I checked all my fuses and then checked the ones under the hood they had 1 (7.5) fuse blown I changed it and my radio worked again so I finished installing the speakers and the front speakers.. I road with it like that for a lil while but didnt turn it up but to about 17-18 volume.. then later tonite I was leaving a party and turned it up to 23 and yet again... blew the same fuse what you think is wrong? HELP ME PLEASE let me know if I may blow my radio or speakers before it happens [IMG]i/expressions/face-icon-small-smile.gif[/IMG] honest and intelligent answers only ASAP PLEASE!!!~~
PS: NO FLAMING YES I KNOW JENSEN SUCKS!!!
Old Jun 9, 2002
scrible's Avatar
This is in a 5TH Gen Civic , 92-95
1994 Honda Civic EX Coupe
Old Jun 9, 2002
scrible's Avatar
I Also noticed that once up to about 19-20 volume the lights on my CD Player blink with the music (not posed to happen) they kinda dim.. as the music beats.. and I dont have any system in my car to drain my batt.. so I dunno.. PLEASE HELP ME!!
Old Jun 9, 2002
mohawkboom's Avatar
Hmmm.. it's possible the Power wire (+12) volt wire is a little corroded at one of the harnesses and and it causing too much resistance in line which overheating your HU and shorting it.... It's also possible that the new speakers you installed are shorting something.... Either way..problem is a short somewhere..time to re-check all wiring
Old Jun 9, 2002
scrible's Avatar
Oh... that will be a b*tch to do [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jun 9, 2002
scrible's Avatar
I was told a minute ago by Advanced Auto Parts that it was my battery (I have a faily small *** battery) and it was not putting out enough power to run everything, aswell as a higher amper alternator so what do you think? New battery/alternator or go ahead and re-wire? Also if anybody can get me a wire diagram of the 92-95 5th Gen Civic would be GREATLY appreciated...
Old Jun 9, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
you wont need a new battery or alt if your just running a new deck and some speakers. unless your going a full out system with 1k+ power. your stock will be more than plenty.
Old Jun 12, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
I wouldnt replace the battery just add a battery in your trunk just for your system
