Amp gets hot so where do i put it
Old May 28, 2002
DYCE's Avatar
DYCE is an unknown quantity at this point
Ok i have my amp screwed to my box , it gets hot and i dont want to set the trunk on fire or nothing..where is another place that i can put the amp so that it will be safe to operate......back of seat ...what are some options or tips for amp placement especially if it warms up pretty good
Old May 28, 2002
mohawkboom's Avatar
It's safe where it is.. most amps get fairly warm when under heavy loads.
Rockford Fosgate amps seem to get downright toasty, as do Cerwin Vega amps...Unless you can fry an egg on it don't worry.
Cheers
Mohawk
Old May 28, 2002
DYCE's Avatar
yeah it's an alpine, i just wonder is it getting enough air to cool it i the trunk.....it shuts off when i crank it up to the max but it comes back on when it cools off some.....is it normal for headlights to dim when you crank it up a bit....how can i correct this problem
Old May 28, 2002
mohawkboom's Avatar
If it's getting that hot, I'd be willing to make a bet that you have your subs wired improperly and getting too low of an ohm load. If the amp puts out more than 400Wrms a little dimming is to be expected when you crank it.
Which amp do you have specifically. and which subs?
Old May 28, 2002
DYCE's Avatar
I have an Alpine MRV T502 2/1 Channel Amp.....i have it bridged ...i have two ORion XTR 3 subs 10's
Old May 28, 2002
mohawkboom's Avatar
those subs are they DVC 4ohm, or single voice coil subs
Old May 28, 2002
DYCE's Avatar
single voice coil
Old May 28, 2002
mohawkboom's Avatar
And you have the amp bridged for more power right?...
If so. Your running a 20hm mono load on a 4phm mono stable amp.. not good.
If you have wires in 2 channel. some of the amps transistors may be friend and your amps running as a pure class A amp. Not good either...
Check the wiring . If it's bridged. Wire it in 2 channel. 1 sub to eac channel. You'll lose a little power..but you won't be driving a firehazard.
Cheers
Mohawk
Old May 28, 2002
DYCE's Avatar
but how do i keep the boom that i want
Old May 28, 2002
mohawkboom's Avatar
Get an amp that's 2ohm mono stable...
Old May 28, 2002
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
Bazooka makes an amp called el1500, it pushes 500watts @ 2ohms. It only costs $189. I have one on a jl 15 w6, and it kicks assthere is a pic of it in my profile. jbl makes a good mono amp too, it costs a little more, but it is awesome.
My Shizzit
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
usajags84
May 10, 2015 08:11 AM
BootyDo
May 8, 2015 05:36 PM
