Dual 12s in civic
Re: Dual 12s in civic
1 - Your “ stock” electrical system has a 100amp main fuse for everything.
So do not connect that amp to any part of the stock system. You need to run dedicated power wires.
2 - alternator output
Not only is your factory alternator not able to supply that level of power, your PCM monitors electrical load for the stock wiring but would be clueless to how much power is being used by the amp so it won’t increase alternator output as your cranking it up.
boostaddict
Aug 4, 2005 01:19 PM
asc070
20
Apr 17, 2005 09:48 PM
