Fuse Box
Old May 23, 2002
Crash2002's Avatar
Crash2002 is an unknown quantity at this point
Fuse Box
i opened the fuse box under the hood and i noticed 2 screws, are they for AUX power? can i run my amp off that or is it easier to run power to the amps from the battery.
Old May 23, 2002
aldini's Avatar
aldini is an unknown quantity at this point
dude those screws are TIGHT were you able to unscrew them? I tapped straight into my batt
Old May 23, 2002
gipperkid's Avatar
gipperkid is an unknown quantity at this point
You can't get those screws off with a screw diver.....MUST use a 8mm socket. Those two pionts are how your fuse box gets the 12V power from the battery. If you look, you will notice two white wires connected to the termials that are bolted on. Follow those two wires and they lead straight to the battery. Just a little FYI. I would tap my amp power from the battery itself. I only used the fuse box poit for a small wire for my neon transformer.
h4ldol
19
Jul 28, 2015 01:01 AM
Dave1984
Jul 22, 2015 06:10 PM
Civic65
Jul 19, 2015 10:13 AM
