Electrical power lost while driving
Driving when suddenly headlights started to dim, radio got fuzzy and went out, gauges all went down. Eventually I pulled the car over stopped it and it shut off. Then next day changed the alternator and battery, and charged it up to start. Drove it for about a week until the same problem happened again. This time I changed a ground that could have been faulty ( it was rusted and corroded). Once again charged it up and drive it for a few days. Finally changed the ignition switch and charged it up. But as soon as the jump pack is pulled of the car it begins to have the electrical failure. Now the car will only start with the jump pack on. Idk what else could be the problem???
Re: Electrical power lost while driving
you could have tested the alternator and charging system before hand. throwing parts at it starts to become the norm.. what are the voltage charging? whats the amperage? is there a draw?
You're gonna kick yourself in the azz if a blown 25 cent fuse caused you to needlessly replace a battery and alternator and ignition switch
Bugman1400
Feb 21, 2017 12:13 PM
ANW89
Jun 19, 2013 10:39 AM
BWags
Feb 12, 2011 09:21 PM
revo00099
Feb 19, 2010 09:02 PM
