Location of ECU on 2005 Si-G.
Old Nov 20, 2017
redrocket87's Avatar
Huckin' Hippie
redrocket87 is an unknown quantity at this point
An alternator issue ( loose mount bolt) may have taken out my ECU so I'm was going to see if I can pull out my ECU and get an ID on it to start my search. I thought it was in behind the console, but then I saw it posted on another forum that it's in behind the Glove box. Before I start pulling things apart I want to start in the right place. It's a Canadian model 2005 Civic Si-G.
Old Nov 20, 2017
Colin42's Avatar
Re: Location of ECU on 2005 Si-G.
looks to be behind the glove box according to the repair manual. you can probably see it if you stick your head under the dash on the passenger side. or pull down the glove box
Old Nov 20, 2017
Pry the two ears out of the glovebox sides so it can flop open all the way to the floor.
The ECM is behind there.
See this thread for more tips on getting it out
(cut the plastic strip)
https://www.civicforums.com/forums/3...emove-ecu.html
May as well replace cabin filters (pair) while you are up in therre too
Old Jan 7, 2018
Huckin' Hippie
Thanks Guys I appreciate it. Now I just have to see if I can find one to replace it! While I'm at it, where do I find the ID for the ECU so I can find a Match?
Old Jan 7, 2018
Part numbers are on the PCM, you'll see the stickers when you get it out
Or look it up in a Honda dealers online parts catalog (but it may not show the original numbers, only the most recent replacement numbers)
torontohondaparts.com
Old Jan 9, 2018
Huckin' Hippie
Thanks again EZONE! When I can get at it I'll check the numbers and call around a few wreckers to find a used unit, I've already have a garage that'll flash a used unit to my key!
Old Mar 4, 2018
Huckin' Hippie
OK I got a ECU that is an exact match and I'm going to get it Flashed and install it, but I can't find the link anywhere that shows how to ground the alternator with a wire to the block so if the bolt comes loose again I don't fry this ECU. Can anyone help? It was on the thread, but I can't find it!!!!
Old Mar 4, 2018
Just buy one and bolt it on?
Connect alternator housing to a solid ground, be it the block, trans, ground cable attachment points or the battery negative clamp itself
