Electrical stereo issues.
Old Jan 17, 2016
manfredww1's Avatar
manfredww1 is an unknown quantity at this point
Ok, I am less concerned about the tweeters anymore and now I cannot get my deck to turn on. I have rechecked the wires and after not changing anything from the way they were before.
I saw a spark when I removed the deck coming from one of the wires making contact with another (wiring harness).
I have checked my fuses (all) and they do not look seared or blown(broken in the center) so I am not sure what is causing the issue.
Also my door locks only work when I the car is on. Does that help narrow down the problem. Any help would be appreciated . Thanks
Is it possible that fuses could not work with out looking blown?
Also I have two ground wires. One coming from the deck itself and another from the wiring harness attached with a butt connector. I have connected them both to a screw on the chassis and at another time, taped one and attached the other to the chassis. Which way is ideal?
Civic 2002 EX stock speakers with Pioneer DEH-1300mp deck
Old Jan 17, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Electrical stereo issues.
Buy a multi meter and start testing the wires.
Also sand the body where you are using the screw to connect to ground.
Old Jan 17, 2016
manfredww1's Avatar
It was the back-up fuse. [solved]
