Removing The Dash!!
Old May 12, 2002
DeadDreameR's Avatar
DeadDreameR is an unknown quantity at this point
Removing The Dash!!
How do i go about removing the dash to get a new headunit in???
I have to put a Blaupunkt RDM126 in...
I have no idea one of my buddies said the console with the dash clips in and comes off... He broke one of the clips and we stop'd...
Stero Stats:
Subs - 12" Mculley Subs
Amps - 2250 rioin Amp , n , 600a4 Rockford
Speakers - MB Quartz
Unit - Blaupunkt RDM126 Keycard
-Thanks Chris
Old May 12, 2002
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
Look at the top of the page for DIY. Here is the link for the HU Removal. Click Me Click Me for removing the HU.
Old May 12, 2002
Ok one more question... ehhe
Is there any place on this site that tells you the best way to run power wire and stuff??
Or no
-Thanks alot for your help!!!!!!!
-Chris
Old May 12, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
I ran the power wire up the passenger side door frame under the plastic piece, and the RCAs up the driver side, you can also run the rcas up the center console all the way to the back. Then put the ground wire on the bolt for the rear seat
Old May 12, 2002
where did you run the power wire??? is there a hole in the firewire on the passenger side? and if yes where is that located?
-Thanks Chris
Old May 12, 2002
Bdubb's Avatar
Bdubb is an unknown quantity at this point
I just did all of mine and have pics so you guys can check it out the HU comes out easily after removing the two 10mm bolts remove the cigarette lighter panel first then the two bolts then pull like a **** as for the power cable i ran 2gauge throught a grommet on the passenger side floor underneath the sounddeadening material where your feet would go. if you want pics email with what you want pics of my civic is completly taken apart and dynamated right now i have a digital camera so i can email you pics just holla at me at bosswaltz@hotmail.com
Old May 14, 2002
2K1SilverHX's Avatar
2K1SilverHX is an unknown quantity at this point
The greatest chore is if you have to run a direct power lead to the battery... I had to for my "high power" Alpine deck... They storngly say Do Not use the factory wiring.
Jul 12, 2015 11:54 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
OptimisticWay
Jul 10, 2015 04:31 PM
jody501
Jul 10, 2015 11:01 AM
ballmich
Jul 9, 2015 11:59 AM
