Two way 6.5 or components??!?
Old Aug 22, 2014
Najitsu's Avatar
Najitsu is an unknown quantity at this point
Replacing front speakers-should i replace just the door panels with 6.5 two ways or go ahead and replace with components -including the tweeters.
What do you guys think will sound better in the front of an ex coupe?
Old Aug 22, 2014
GolNat's Avatar
Prelude Owner
Re: Two way 6.5 or components??!?
I think including the tweeters will be best. The more you can separate the different sounds the better.
Old Aug 22, 2014
Najitsu's Avatar
Would it be a good idea to replace the 6.5 inch door speakers with the two way speakers and then later down the road replace the tweeters in the sail panel?
OR
Will I have an issue with the tweeters being out of sync?
Nice rims by the way!
Old Aug 23, 2014
GolNat's Avatar
Prelude Owner
Thanks.
No issues with doing it that way. Do you have tweeters already?
With the addition of tweeters you don't need the 2-way in the door since the tweeters take care of the sound that a single speaker would be missing. Having a 2-way in the door and tweeters is more then you need. You would get better sound separation with singles in the doors and the tweeters up high.
Old Aug 23, 2014
Najitsu's Avatar
Thanks.
Well I have an 02 civic Coupe EX model that has the stock components-tweeters in sail panel and the woofer in the doors.
You made a lot of sense, I will just get a new component system to replace the stock speakers and then later down the road invest into a 5 channel amp to power everything in the car.
Old Nov 15, 2014
Hensinger2010's Avatar
Meh...
Hensinger2010 will become famous soon enough
Thanks.
x2
I have pioneer 2-way 6x5's, high pass crossovers and the stock tweeters, way too much and slight buzz in the tweets, components soon
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
