2004 Civic LX Left Head and Brake Light Out
Old Jan 1, 2014
jeltman's Avatar
jeltman is an unknown quantity at this point
Both left hand headlight and LH brake light suddenly went out. Engine compartment fuses all good, new bulbs did not fix. LH Back signal light works (same bulb) brake only does not. Any clues?
Old Jan 1, 2014
Re: 2004 Civic LX Left Head and Brake Light Out
They probably quit separately, you only noticed them at the same time. There is no common circuit between one headlight and one brake light.
The tail and brake share a single bulb on each side.
The turn signal is a separate bulb on each side.
Any clues?
No, you have to do the checking.
What is missing from the brake light bulb socket? Power or ground? (positive or negative)
What is missing from the headlight? Power or ground?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
chgofirefighter
Apr 18, 2015 08:08 PM
GH04si
Apr 15, 2015 08:13 PM
showoff
Oct 30, 2001 06:41 PM
