Help with Amp/sub wiring (ohms, watts, etc)
Old Dec 30, 2013
Guaps's Avatar
Guaps is an unknown quantity at this point
My brother gave me his old subs (two 10" 300W RMS 4 ohm subs - Kenwood KFC-W2511) and I bought an amp (Hifonics Gladiator GLX1000.1D 1000W mono). I need some help understanding what I'm doing with the wiring.
I wired the speakers in parallel so each sub goes directly to the amp according the diagram in the amp instructions. The instructions say this is for "2-OHMS SVC EACH MINIMUM, or 4-OHMS DVC EACH MINIMUM". I have no idea what that means. Is my current wiring ok? (It says 2 ohm minimum. Is 4 ohm higher or lower than 2? I know that sounds like a stupid question but if it's a measure of resistance, 4 ohms would be more resistance and thus is confusing me for some reason) I think SVC = single voice coil and DVC = dual voice coil so I think mine are single voice coil.
Would it be better to wire the speakers in series instead? I have no idea what that does to the ohms or wattage. I asked the jerk off at the store where I bought the radio if my 1000W amp @ 1 ohm was the same as 500W @ 2 ohms. He laughed and said "no - 750. you should just let us do the install". So now I'm determined to learn this on my own just so he doesn't get my money...
Old Dec 30, 2013
GolNat's Avatar
Prelude Owner
Re: Help with Amp/sub wiring (ohms, watts, etc)
Don't pay them, it's not hard.
If you hook the speakers in parallel you will cut the resistance in half. If there is only 1 positive terminal and one negative terminal on the speaker then they are single coil. Yes 4 ohms is more resistance then 2 ohms. Since you bought a mono amp you only have one output. So you wan to wire the subs in parallel (+) to (+) and (-) to (-) then run those to the amp. Lowering your resistance increases your wattage and visa versa.
What is the RMS of your amp? You can overdrive a sub by a certain percentage (can't remember off the top of my head).
**read up on Ohms Law. It explains the relationship between, Volts, Amps, and Resistance. Watts is Power which is defined as P = Voltage x Current.
60W lightbulb, 120 Volt input, do some algebra Current = Power/Voltage so 60W lightbulb draws .5 Amps or 500 mA.
Old Dec 30, 2013
Guaps's Avatar
The amp is 1000W RMS.
So the amp actually has two (+) and two (-) so you can connect two subs. So right now each sub is connected to its own place on the amp. So that means they are each at 4 ohms right now and that's is ok if I understand you correctly.
Just curious - if I wire them in series, what would the ohm and wattage be for each speaker? I'm trying to learn how this works...
Thanks for your quick reply
Old Dec 30, 2013
Kennykid2002's Avatar
Kenny the Ricer
You'll want to wire your speakers in parallel, resulting in a 2 ohm load on your amplifier.
Here is the correct diagram for your setup.
If it confuses you, it's very simple.
Wire a positive and negative from your amplifier, directly to your first sub.
Then, wire another positive and negative from your first sub to the second.
Old Dec 31, 2013
GolNat's Avatar
Prelude Owner
Yes 4 ohms is good for your amp but what is the 1000W RMS rated at (4 ohm or 2)? If its 1000W at 4 ohms then you are under powering the subs by hooking them up separately.
Hooking them I'm series would result in an 8ohm impedance at 150W (not good for your amp).
Old Dec 31, 2013
Guaps's Avatar
Thx! This is exactly what I was looking for. My amp is 1000w ar 1 ohm. I wired them like the diagram above.
I understand the wiring, but I have to admit I don't get the ohm thing at all on that diagram. If each speaker is 4 ohm then why is it only 2 ohm load on the amp?
Old Dec 31, 2013
GolNat's Avatar
Prelude Owner
It's a 2 Ohm load because that is what happens to impedance when you hook two resistant loads together in parallel. If they were hooked in series you would add them together.
Old Jan 1, 2014
Kenny the Ricer
That's just how electricity works.
You're not going to get your 1 ohm load with those speakers.
The only way you'd have a 1ohm load is if you had a pair of 4ohm DVC subs or a single 2ohm DVC sub.
@2ohm, your amp will push 750W RMS, and since you have 2 subs, that will be 375W RMS each.
Your speakers are only rated up to 300W RMS, so you'll want to tone down your amp a bit.
Old Jan 2, 2014
Guaps's Avatar
I finally realized why I have been so confused about this. I was confusing the terms series and parallel.
You have both been awesome. Thanks. I got it all wired up and working over the new year yesterday. I'll figure out how to turn things down a bit on the amp so I don't ruin my subs - thanks for the advice.
Happy New Year to you both!
Old Jan 2, 2014
GolNat's Avatar
Prelude Owner
Yes that would make things confusing. Glad you got it all figured out.
You should need to turn it down. You can overdrive a sub but I don't remember buy how much. I'll see if I can find it (I want to say it's 50%).
Happy New Year!
SimpleUser
Apr 24, 2021 02:54 AM
sch2cm
Jul 21, 2015 09:58 PM
Jul 12, 2015 11:54 AM
robbie374
Jul 7, 2015 02:56 AM
