2001 Civic Voltage Issues
Old Jul 1, 2013
bmk6795's Avatar
bmk6795 is an unknown quantity at this point
Alright i have a 2001 civic ex with the d17a2 engine. This is my issue, when i first start driving the voltage stays at 14.4 volts. After 10 minutes or so of driving, the voltage drops to 12.5 volts. If i let off the throttle or idol long enough the voltage will go back up to 14.4 volts. If im driving over 65 mph the voltage will stay at 14.4 volts. If i turn on headlights/ac/defrost anything like that the voltage will go back up to 14.4. Any idea what could cause this? Someone said that it could be the voltage regulator but im not sure. If anyone has any ideas id appreciate it.
Old Jul 2, 2013
GolNat's Avatar
Prelude Owner
Re: 2001 Civic Voltage Issues
The car has a load detection system on it that only increases the voltage when it is needed. Sounds like the fluctuations you are seeing are due to that, which I believe are normal.
Old Jul 2, 2013
bmk6795's Avatar
I was afraid of that, now i know there is a way to bypass that, any idea how?
Old Jul 2, 2013
CraigW's Avatar
It is normal operation of the ELD system.
Old Jul 2, 2013
GolNat's Avatar
Prelude Owner
No reason to bypass it. It's working like its suppose to.
Old Jul 2, 2013
bmk6795's Avatar
Well when my new system is ready to go in i cant have the amps receiving 12.5 volts . But i have found out how to bypass it so its all good, thanks for the help.
Old Jul 2, 2013
sl33pyriceboi's Avatar
That's normal. When you see the 14v is when your alternator is charging your batt or giving you car the required extra juice.
Old Jul 2, 2013
bmk6795's Avatar
Yeah i understand that now. I still need to bypass it so when my new system is built and ready to go in i can feed the amps the proper 14.4 volts not 12.0 - 12.5 as that'll eventually kill them.
Old Jul 3, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Just take out the ELD like I did, it might be brown colored. On a 6th gen it's in the fuse box under the hood. Forget if different for your 7th gen.
Then the alternator will aim to output the ~14.4V constantly. Won't harm anything, will just use a miniscule bit more gas and battery might run a few degrees warmer and all the electrical systems in the car will have more power.
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
