Removing door panels?
Old May 7, 2002
Lockhart's Avatar
Lockhart is an unknown quantity at this point
I need some help...
I've read everything I can find on installing component speakers and I've read the DIY on door panel removal.
I just tried to remove my drivers side panel and everything came loose as the DIY said
except the section just below the tweeter pod wouldn't budge.
The tweeter pod section came loose okay.came loose
I tugged, lifted, and pulled but with no luck. what is holding on in there?
Is it another little white plastic connector? A screw?
Having never done this before can be intimidating.
I'm afraid of breaking something.
The speakers I have to mount are Infinty Kappa 50.3cs.
any wiring tips?
Thanks
Old May 7, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
Once you get all of the screws out, by the door open latch, and the door arm rest, the only thing holding the door panel in are the white plastic clips. There is one below the tweeter pod, and one to the right of where the door opening handle panel was. Once you pry this out the door panel should be able to swing outward from the bottom of the window sill. Pull on it and it will pop out, then lift upward when you pull the panel out, it helps with the window lowered. Hope this helps.
Old Jan 11, 2004
manahoonie's Avatar
how about disconnecting the power windows when taking off the door panel? I took my panel off completely, except for the connection to the power windows. I coudn't get that piece to pull out of the socket. any help?
+ manahoonie@yahoo.com
Old Jan 11, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
^^ You gotta press the release tab
Old Jan 11, 2004
manahoonie's Avatar
i've tried that, but it still seems like it's locked in there
Old Jan 11, 2004
Jaykuai's Avatar
ish...
try pressing it with a small screw driver or something..
Old Jan 11, 2004
manahoonie's Avatar
aiight. i'll try tomorrow, as it is night now, and it was cold before when I was trying to get it off, so my fingers were frozen.
Old Jan 12, 2004
Mystic3030's Avatar
Even when you press the release tab it's still in there pretty good. Just press down the tab and give it a good tug. Or you could use a flathead screwdriver and pry it out.
Old Jan 12, 2004
DJPark's Avatar
DJPark is an unknown quantity at this point
It is rough getting the plug out. Honda did a great job to make sure that people couldn't pull it out. I was able to do it like 2x (ran into problems and had to pull it back off). The other couple times I just had someone hold the door panel if they couldn't get it out themselves.
Old Jan 13, 2004
JCiv03's Avatar
DIY door panel removal
http://robnkester.com/gallery/view_a...album07&page=1
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
h4ldol
Jun 3, 2015 03:26 PM
MamaBear2015
May 18, 2015 07:37 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
