blinking check engine light then car shuts off.
Old Jan 9, 2013
mislabeled's Avatar
mislabeled is an unknown quantity at this point
My 2001 Honda civic ex recently got a p1361 tdc code. I turned off the car and let it reset and it was fine for a day. But then today while I was driving a made a sharp turn. Pretty fast and my check engine light started blinking. The car rpm started going up then down then it started idling higher then normal. I drove it home and tryed turning it on again in a couple hours but it did the same thing and just shut off. If anyone can help it would be great.
Old Jan 10, 2013
Re: blinking check engine light then car shuts off.
P1361 is intermittent interruption of the CMP signal.
Here's what the computer had to see before it set the code:
Malfunction Threshold
More or less than four TDC sensor pulsing signals during intervals between standard pulses. This status occurs 30 times.
Recent work done? See if the CMP connector isn't plugged in all the way.
Possible wiring issues, bad sensor, cam out of time?
If the PCM thinks the cam is out of time, it shuts down the engine.
Worst case, check this and pay attention to the VIN numbers this applies to, because the problem was fixed during the production run. Bulletin tells you to inspect camshaft end play so you will need a real shop manual if you don't already know how.
I have yet to actually see one of these cars with this problem. http://ww2.justanswer.com/uploads/th...1_and_1362.pdf
Old Jan 10, 2013
mislabeled's Avatar
I checked the VIN number and my car is one of the cars in that service bulletin.
Old Jan 10, 2013
The next step is to inspect, according to that bulletin.
DIAGNOSIS
Remove the valve cover. Check the camshaft for
excessive end play. The maximum allowable amount of
end play is 0.5 mm (0.02 inch)(see page 6-40 of the
2001–02 Civic Service Manual).
• If the end play is more than 0.5 mm (0.02 inch), go to
REPAIR PROCEDURE.
• If the end play is less than 0.5 mm (0.02 inch),
proceed with normal troubleshooting.
So if the end play is less than that 0.5mm (0.02 inch) specified above, this is not your problem. Ignore the bulletin and carry on with normal troubleshooting.
Get a service manual and check the end play the way the book says to, if you think this may be the problem.
HTH
Old Jan 11, 2013
mislabeled's Avatar
It was in a accident and I recently had a lot of work done to the front end and some to the exhaust
Old Jan 12, 2013
Whoooo boy.
Human error can be the toughest to figure out.
I might verify the wiring for the sensor(s) in question are all electrically good to the computer first.
Voltage, ground, and signal.
Old Jan 12, 2013
mislabeled's Avatar
They all work fine but one thing I knowest was when I 1st start the car at night and turn on my lights then the heater it makes a squealing noise
Old Jan 12, 2013
Loud screech?
Belt slipping.
Alternator belt is too loose, it needs tightened or replaced.
Inspect it and solve that problem before it lets the battery run dead while you drive.
If the engine has to come apart though, this can be addressed at that time.
Xuhme
21
Aug 7, 2023 03:40 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
