dash removal+cd changer install
Old May 5, 2002
RexWatson's Avatar
RexWatson is an unknown quantity at this point
i just got a cd changer and i want to know how to remove the dash so i can hook it up to the stock unit.
also any advice on which wires i should plug into for power (need always 12v and 12v only when car on).
when i run the cable from the HU to the changer in trunk, i want to run it under the carpet. do i have to remove the seats and all that to remove the carpet or is there an easier way to route the cable?
how do you get extra cd magazines?
oh yea this is an auto 2k1 and i did a search.
Old May 6, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
maybe your sig is denying your replyies.
Old May 6, 2002
WhiteRabbit's Avatar
deck removal is easy, tehre is a diy. then you can use scotchlocks to easily tap into teh ACC wire (i forget which color it is) and constant power if you need it, i forget. black is ground, you can ground anywhere, use teh amp install DIY for that one, if need be.
everything else is plug and chug. you will not need to remove a single body panel, seat, or piece of carpet to run anything. it can be tucked be hind panels, ran under hte seat, throught the center console and under the carpet with minimal work. you can use the rear seats and under the front seats as an entry and exit point i fyou wish for wires. simple!
Dangerousjordan
Jul 23, 2015 11:11 AM
Markwnjr
Turbo
Jun 25, 2015 06:36 PM
pincookie1
May 4, 2015 12:22 PM
mwwhonda
Dec 5, 2001 10:52 AM
BumpinCivic2k1
Nov 18, 2001 04:44 PM
