Disable security but keep keyless entry?
Average Old Guy
Okay, I've got an 03 with keyless entry, and I'd like to disable the alarm interface portion if I could. Is that possible?
I find the alarm to be a crap shoot as far as whether or not it's going to go off at any particular time. Sometimes the LED is blinking--other times not. Sometimes I can get into the trunk with the key and nothing. Other times the alarm goes off. I haven't been able to predict (with certainty) when it's going to go off or not. I hate the unpredictability of it.
I love the keyless side of things though. I like to be able to lock an unlock, and I like to have the lights flash, etc when I do it. I just want no "security" in the flow of things.
Is that possible?
Is that possible?
Re: Disable security but keep keyless entry?
if you have the oem honda security system, its just a matter of unplugging the wire harness that plugs into the unit. the keyless unit is separate. it should say on the unit whether its alarm or keyless. just unplug the connector and tie it up somewhere. its located under the driver side dash when you remove the lower cover and fuse panel cover. i believe the alarm box is above the hood release and the keyless box is more towards the middle like under the steering wheel.
Average Old Guy
That worked perfectly. Thanks so much!
It was the biggest item under the dash in that area... Green plug. Easy to unhook or re-hook any time I want to.
Funny about security systems... It seems that we owners are the only ones that ever set them off...
yeah its more of a problem than its worth. i dont even have the keyless anymore. got tired of the car deciding when the doors should lock.
h4ldol
Apr 24, 2017 08:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
frank_kleng
Sep 29, 2015 10:55 PM
