Stock Alt Max?
Re: Stock Alt Max?
It's probably on the borderline...that setup would draw about 80 amps at peak (which it would never likely hit) and the stock alternator can put out 80 amps peak as well, mind you there's a whole bunch of other electronics using it for power, so the amount of juice being used to charge the battery is less than that. I have an 850w/200w setup, along with a number of other aftermarket electronic components, and until I added the second 200w amp, I had no issues as long as the battery was good. After adding the second amp, I went through two alternators until I decided to get a 160amp alt which for the last year, has done the trick.
TL;DR:
You should be fine, just don't run both amps cranked to full volume whenever you leave the house lol
TL;DR:
Re: Stock Alt Max?
well, stock alt barely puts out 60 amps on a good day, and remember any aftermarket electronics will not be recognized by the ELD (electronic load detector) so under certain driving conditions the alternator will cut out and you will be running on 11.5v or so. in which case your amps will slowly start eating away at the battery without the car knowing.
the alternator shuts off when the following are true, and this happens quite often on a normal drive. remember this is not counting the amp draw of the stereo equipment, which will be invisible to the car.
- Load below 10A
- Speed below 40 MPH
- Engine speed below 3600 RPM
- Coolant temp above 140 F
- A/C off
- Intake air temp above 65 F
- Brake switch off
- Fuel cut-off not active
- Load below 10A
- A/C off
- Brake switch off
Re: Stock Alt Max?
if you put in a voltmeter, you can monitor the voltage readings and adjust your driving accordingly so that the alternator stays on more too. but it will still be annoying when the voltage goes from 11.5v to 13.5v and it does affect the rms output of the amps. same as with lights and anything electrical. most of the time, having your foot on the gas will cut off the alt, coasting will kick it back on, as will sitting still in neutral.
Re: Stock Alt Max?
Volt meters have saved my *** a few times...also, I forgot you Americans have that ELD whatchama-call-it...Canadian made civics don't have it, so my alt runs at full power 24/7...that would also explain why most of you guys cam hit 40mpg when I come nowhere close.
Re: Stock Alt Max?
i guess if it really becomes an issue and you dont care about mileage or longer alt life, just find the ELD, remove it, and jumper the two wires together. engine light will be on, but alt will charge all the time. might be worth considering if you have big stereo. but voltmeter is still wise because the potential of overcharging the battery is there.
Re: Stock Alt Max?
I blew the voltage regulator in my last alternator and everything started acting crazy in the car...the shop that tested it said he let it go to 30v before he shut it off cause he didn't want to damage the tester lol....I can't believe nothing in the car got fried.
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
