hard start
Old Oct 13, 2011
olhos de anjo's Avatar
olhos de anjo is an unknown quantity at this point
hard start
my car takes to get started. the battery is new. spark plug as well.
but he always takes approximately 5 seconds before actually starting. rurrurrurrurrurrurVrum ...
my country is hot.
civic 2003 lx 1.7
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1067& transactionid=1318537132-20141125193&posted_by=olhos_autoblankauto_de_autob lankauto_anjo_www.civicforums.com&youtube_video_id =ByynP0MX4Is[/autostream]
Old Oct 13, 2011
Re: hard start
Olhos de anjo, onde tu ta? Nordeste?
Old Oct 14, 2011
mac25's Avatar
Dr Krieger of Modification
Re: hard start
my car also starts hard and it sounds like the OP's storry. i really hope someone can suggest what the issue is. so far my car will always make the turning over ignition sound. but this scares me how the OP's car will not utrnover for soo long, and my ignition seems to be getting worse.
-battery is good does not dye if left running after the ignition is off.
-plugs are always new
-the ignition turns over and sounds normal.
how do you know if a starter needs to be replaced?
my only other thought is that it's something in the fuel delivery side of things since if i turn the key to on twice, priming the lines, the car seems to start in 2 cranks of the ignition or if i've been running the car then stop for a for a few minutes it will start in 1 or 2 turns. but if i just try to start it after it's been sitting for a night. it will turn over forever and not start, then after i turn the key to off and try again it will start in 1 or 2 ignition turns.
Old Oct 14, 2011
sl33pyriceboi's Avatar
Re: hard start
1. go get a ground kit. that'll help. check electric's big 3 i the FS section.
2. when you did ur spark plugs, did you properly gap them or did you just throw them in?
3. what is the cold CCA and CCA of ur battery? if u have a crappy/low CCA then it harder to deliver that power to ur engine
4. also check if ur terminals are all corroded.
Old Oct 15, 2011
mac25's Avatar
Re: hard start
actually i am missing one ground cable i took out because it was rusty as a mo. i'm running zero gadge on my batterie but the ground from the block to the body is the stock small wire. i'll buy one tomorrow! thx for reminding me!
Old Oct 15, 2011
Re: hard start
i am afraid of the alcohol content that is variable in his country... it's clearly portuguese, potentailly brazilian guy...
Old Oct 16, 2011
mac25's Avatar
Re: hard start
on second review i do have a zero gadge ground to the block... so the mistery continues.
Old Oct 16, 2011
Re: hard start
centro oeste, amigo.
this does not happen to me. even with the engine warm...delay...
1. 1. go get a ground kit. that'll help. check electric's big 3 i the FS section.
i will check. but... the spark plugs: properly gapped.
the battery is new. original honda . cca= - 18º C
it's... possible.
Old Oct 17, 2011
Re: hard start
i do believe you should have a gasoline tank for "cold" starts - is it working properly?
CarStuff
Dec 6, 2020 12:52 PM
jbradley4809
Apr 7, 2017 04:23 AM
MamaBear2015
May 3, 2015 02:17 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
black2k1vtec
Dec 6, 2001 09:49 PM
