will these fit?
will these fit?
Just need to know if i can install this in my LX sedan. according to the size and depth of the speakers, it seems like it should fit in my front doors but it is not listed as such according to crutchfield.
http://www.etronics.com/product.asp?stk_code=inf605cs
You can buy a 1'" thick 2'x4' piece of MDF from home depot for around 4 bucks. Just use a saw to cut the spacers and you are set. Won't even have to cut the sheet metal. Had to do it to fit my MB Quart QM216's in. Fit like a glove after mounting the spacer.
You don't need to cut the sheet metal if you use spacers. I, on the other hand, chose to cut the sheet metal to fit my
speakers. It was pretty fun with a dremel, and pretty painless. Not much to cut either!
edy
edy
Or the doors are too shallow..[IMG]i/expressions/face-icon-small-smile.gif[/IMG]. either way. if you wanna roll your window down all the way spacers are a good idea [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
the shallowest speakers you can find will still rub..[IMG]i/expressions/face-icon-small-smile.gif[/IMG] the OEM speakers have mini magnets and are built onto a 3/4" Spacer..
rnaodm
Sep 21, 2015 12:42 PM
Dave Brabant
Sep 12, 2015 08:39 PM
Biggunschad
Sep 11, 2015 04:06 PM
