New Battery Suggestions
Old Jul 12, 2011
blorshbough's Avatar
blorshbough is an unknown quantity at this point
hey, looking at getting a new battery for my 2003 lx, just wondering what would be a good one as i have a sound system (sub, amp, speakers) and would like to turbo someday soon
Old Jul 12, 2011
7genmarathon's Avatar
7genmarathon is an unknown quantity at this point
Re: New Battery Suggestions
I have a Duralast Gold Top since last march or so. Works great I run about 661rms right now. I do have a little light dimming but that if I were you I would upgrade to the next size up battery from stock size. It will fit in the battery area but you gotta take out the bin the battery belongs in.
Old Jul 12, 2011
honda 500cca group51 is the best stock size battery, made by interstate i think and its only $100. best compromise of weight and performance. bigger batteries are much heavier.
Old Jul 12, 2011
lowlife9's Avatar
duralast gold is the best bang for buck battery you can get. i have the largest one that can fit in the bay ill give you the model number tomorrow.
Old Jul 12, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
I HATE walmart, but their Everstart MAXX batteries are top-notch for price/performance. They're made by Johnson Controls, so they're high quality.
Old Jul 13, 2011
maxtierney's Avatar
EM2ti
I've been using the Optima Yellow Top 51 for the past 6 years. Red Top would be more for your audio application. You can find them online for $130 to $140 a pop.
Old Jul 13, 2011
any other suggestions?
Old Jul 13, 2011
lowlife9's Avatar
i don't know what else to tell you there are three companies that make basically all US car batteries Delphi, Exide, and Johnson Controls Industries. Delphi makes ACDelco and some EverStart (Wal-Mart) models. Exide makes Champion, Exide, Napa, and some EverStart batteries. Johnson Controls makes Diehard (Sears), Duralast (AutoZone), Interstate, Kirkland (Costco), Motorcraft (Ford), Optima and some EverStarts. so basically like what i told you in my fist post is Duralast is the best one for the money . now if you were running a second battery just for your system i would recommend Kinetic,Shuriken,Stinger,SVR.
Old Jul 15, 2011
sounds good, what were those duralast numbers?
thank for everything guys
Old Jul 15, 2011
lowlife9's Avatar
the model number is ''34DT-DLG'' you can see its a tight fit but a perfect fit all you need to modify is the metal battery tray unbolt the tray then hammer the edges flat so it won't cut into the battery over time your also going to either have to buy or make a new battery tie down for obvious reasons the one in the picture i made from a piece of aluminium that i cut then bent into shape and drilled some holes into.
Old Jul 15, 2011
sl33pyriceboi's Avatar
i have a duralast gold as well. had it for 5 years now. no problem.
its like a 6-7 year warrenty too.
jzhartman
22
Jul 23, 2015 10:42 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
Jul 12, 2015 11:54 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
