ALWAYS DISCONNECT THE BLACK BATTERY TERMINAL!!!!
Old Apr 27, 2002
mohawkboom's Avatar
if you're gonna even look at any witing crosseyed, let alot connect or disconnect or wire anything..disconnect the battery first....
It saves you from both injury and stupidity..
Cheers
Mohawk
Old Apr 29, 2002
WhiteRabbit's Avatar
"I saw a car on fire in the install dept of bestbuy once. Instead of takeing my freinds advice to just pull of the batery terminals and saveing most of the car, they let it burn untill the fire dept arrived and watched them pull the teminals with an ax, the car was junk then. never found out exactly how it started, but I heard bb paid for it and fired the installer"
not my story, but it can happen, if you dont disconnect power and are rushing or clumsy [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 29, 2002
PeArlHoNdA's Avatar
PeArlHoNdA is an unknown quantity at this point
was playin with some lights in the trunk and TOTALLY forgot to disconnect battery, blew a ton of fuses and didnt realize till i was drivin home from workin out and i had NO lights, i had my main right headlight but left was out, taillights were gone, even in reverse. no dash/interior lights at all.....was REAL cute driving home lemme tell ya. DISCONNECT BATTERY!!
PeArLhOnDa
Old Apr 30, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
i forgot to disconnect the wiring harness from the cars connector in my girlfriends sisters 88 corolla when i was taking out the old head unit and installing a new one, and i ended up blowing the fuse when i was untaping the wires. no harm done though, the head unit came with a spare fuse that was the right type (10 amp)
Old May 2, 2002
intensecreations's Avatar
intensecreations is an unknown quantity at this point
Sadly, i learnd this lesson the hard way.....[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] i blew my 4ch amp due to stupidity [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG] well thank god i got it fixed under warranty!
Old May 5, 2002
Ed's Avatar
Ed
Hah, i do'nt learn! twice i've done it, luckily, i''ve only blew fuses, nothign too bad... yet [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old May 7, 2002
2001CivicEx2dr's Avatar
2001CivicEx2dr is an unknown quantity at this point
Same here..
A 40Amp fuse makes a big spark when you let it touch pos and neg terminals at the same time at least I only did it once
Old May 9, 2002
andy22's Avatar
andy22 is an unknown quantity at this point
big sparks
Old May 12, 2002
Desi's Avatar
Desi is an unknown quantity at this point
- when i installed my projectors, i took off the black battery terminal just in case.
Old May 12, 2002
02CivicEX's Avatar
02CivicEX is an unknown quantity at this point
I never do, iv been lucky so far with all of my system installes[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 18, 2002
Machina's Avatar
Machina is an unknown quantity at this point
is it best to unhook both the positive(red) and negative(black) terminals when doing anything electrical??
if so, which terminal should be unhooked first, neg or pos?...thanx...
Old May 23, 2002
armageddon's Avatar
armageddon is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-frown.gif[/IMG]before I knew what i was doing, I blew about 15 fuses installing an amp. Luckily no damage to the car.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 23, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
I guess im lucky that ive never blown any fuses installing audio equipment, unfortunately for me and my own stupid as$ while i was re-wiring the power lead to my remote start/ alarm/ keyless entry 2-way paging system (big description eh?) i accidentally tapped teh pliers i was crimping down the splice with against the grounded steering column framework, heard a loud snap and instantly realized **** this isnt under warranty... Luckily it was only my 40amp ground fuse and the local autozone had ONE 1 left in stock. Too bad they charge like 5 times as much as riceboyz...
Old May 24, 2002
avenger's Avatar
avenger is an unknown quantity at this point
i never do it, but then again I also wire romex hot
Old May 25, 2002
mohawkboom's Avatar
I don't bother anymore either, but if you're not too experianced at installing it's a must.
Old Jun 14, 2002
wishihadavtec's Avatar
wishihadavtec is an unknown quantity at this point
a guy i know didnt disconect tehm and ended up in the er and had black fingers for a while
Old Jun 19, 2002
GoCivicRacerGo's Avatar
GoCivicRacerGo is an unknown quantity at this point
Whenever I'm taking out the Head unit I disconnect the terminals. One time, I was putting new spades on my 4 gauge power wires and forgot to disconnect the terminals. The ground came in contact with the positive for a brief second and sparked, burned some of the gold plateing off the terminals too. Scared the sh*t out of me. So now, I disconnect the terminals everytime I work on the stereo.
Old Jun 21, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
Quote
[hr]Originally posted by: Machina
if so, which terminal should be unhooked first, neg or pos?...thanx...[hr]
You only need to remove the - ground side. Typically black, but don't take that for granted.
Like in my EF9 civic SIR I have both red terminal wires, don't ask, just do.
Old Jun 23, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
yeah d00d you only need to remove the negative, the (-)
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Black91civic
Jun 6, 2015 08:15 AM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
robbclark1
Dec 27, 2001 10:19 AM
