tachometer and stereo installation
Old May 24, 2011
wade623's Avatar
wade623 is an unknown quantity at this point
i just got a 2001 honda civic and i need some information on installing a tach and a stereo first off i have a suntune tach it has red black green and blue wires i read to use the blue wire behind the passanger headlight but i tried it and it doesnt seem to be working is there possibly another place to hook up the rpm wire? and also i have a pioneer avh-p3200dvd deck (double din) that i need to put in and i was wondering if anyone knew where i could get the plastic thing to make it fit
Old May 25, 2011
amamdani15's Avatar
amamdani15 will become famous soon enoughamamdani15 will become famous soon enough
Re: tachometer and stereo installation
if you look at the two harnesses that connect into your cluster one of them has a blue wire with silver markings, you can tap into that for your tach. i dont have my civic right now so i cant tell you which harness and which wire. as for the green, i just tapped it into the illumination wire going to my stereo, i did the one that just turns on and not the one that dims.
as for your stereo, i would go with ebay...something like this:
http://cgi.ebay.com/ws/eBayISAPI.dll...4652&hlp=false
Old May 25, 2011
wade623's Avatar
all right ill check it out and see if i can find it
Old May 26, 2011
wade623's Avatar
I looked and there is not a blue wire going to the gauges is there a place where I can hook it up directly?
Old May 26, 2011
amamdani15's Avatar
hmm, thats weird. whch year civic do you have? i have an 04 VP and thats how i got it for my tach.
its in the blue connector right next to the tab you push to get the harness out of the cluster. here is a pic stolen from the user "Taffy"
edit: dont mind the arrows
Old May 26, 2011
wade623's Avatar
2001 dx
Old May 26, 2011
amamdani15's Avatar
that picture is from an 01-03 civic, because they were doing the swap to the new gauge clusters. maybe you overlooked it? or its tiime for another member to chime in lol.
Old May 27, 2011
wade623's Avatar
I made sure to look and I tried the one behind the headlight but it wasn't working so I'm just trying to find the source so I can hook it up
Old May 27, 2011
wade623's Avatar
Size:  10.2 KBName:  IMAG0016.jpg
Old May 28, 2011
amamdani15's Avatar
argh, im not sure where else you would be able to get a signal. best bet is to follow that wire back from the engine bay and check to make sure its not broken...just use a multimeter
Old May 29, 2011
wade623's Avatar
wow this is really becoming annoying it is stupid they didnt even bother to put one in these cars with a standard trans. how would i use a multimeter to check the wire? i have a digital fluke one but what am i going to connect the leads to and what am i looking for?
Old May 30, 2011
amamdani15's Avatar
i still dont have my civic back yet so i cant tell you where that wire goes. but im basically saying that you follow it back to where it goes (possibly the ecu, but idk) and check the resistance from that point to the end of the wire and that should be zero. if the resistance is not zero then it is likely that there is a break in he wire and you should just tap closer to where the wire is coming from. also, if you want to check if the tach is just not reading the signal, you can touch the black to any ground and touch the red to the blue wire that is behind the headlight. you should get a voltage around 6V and it will fluctuate when the engine i revved. i hope that is fairly clear (although i doubt it). if you have any more questions dont hesitate to ask
Old May 30, 2011
amamdani15's Avatar
by black and red i am referring to the testing needles.
Old May 30, 2011
wade623's Avatar
ill check it out and see if i can find anything out
Old May 30, 2011
wade623's Avatar
well i just checked the voltage it was saying 6-7 volts so now im starting to wonder if its just the tach but last time i used it it worked just fine
Old May 30, 2011
amamdani15's Avatar
let me ask you a question...just to cover basis, because human beings overlook things.
when you tested your tachometer, did you hook up the positive and negative wires along with the signal wire?? if you didnt then that is why its not working. if youre in the engine bay just have someone hold the positive and negative to the battery while the car is on (potentially bad idea, but it shouldnt make a difference if its for a few seconds) and hook up the tach signal wire. if it doesnt work then your tach is probably dried (check the fuse if it has one).
Old May 31, 2011
wade623's Avatar
i did hook it up to the battery the light in the tach turns on just no rpm reading on it
black -
red +
blue (light) +
green signal wire
i also checked the other blue wires in that bundle just in case but nothing on those (i didnt think that was it but i thought i should check anyway just in case)
Old May 31, 2011
amamdani15's Avatar
then in that case, everything points to the tachometer being faulty.
Old Jun 1, 2011
wade623's Avatar
that sucks cause i dont have money to buy another one but thanks anyway
Old Jul 17, 2011
wade623's Avatar
could anybody tell me what pin hole the tach wire should go into? i was thinking about getting new gauges with a tach but im not sure where it would go
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
robbie374
Jul 7, 2015 02:56 AM
