Transmission temp gauge install
Re: Transmission temp gauge install
I need a location to put the sending unit. Wasn't sure if there was a bolt that I could use, or if I should use a fill plug location. I have done some research but I can't find anything, maybe I'm just a moron. But thanks for the help.
well usually the sender will not fit the drain plug hole. most people install it in one of the cooler lines going to the radiator. one is the hot side and one is cold side. i recommend the hot side because thats the fluid fresh out of the trans.
Its sitting around and I would rather just install it. Was going to put it on ebay, but the last ones I've seen on there didn't sell for much so I figured I would give a try. If I can't I'll put it back on the shelf.
Xuhme
21
Aug 7, 2023 03:40 PM
brian257
Jun 4, 2015 08:17 PM
zaboomafoozarg
May 30, 2015 09:21 AM
civic, drain, forums, gauge, gauges, honda, install, installing, necessary, plug, temp, temperature, trans, transmission, wiring
