Rear Seat Enclosure for Subs..
Old Jan 20, 2011
What_It_Do's Avatar
What_It_Do will become famous soon enough
Just wondering if anyone has built a rear seat enclosure in their 7th gen. Coupe?
I'm talking, interior completely out and working a large enclosure through the door to replace the rear seats.
Was thinking 2x15's if I have enclosure space, but I would settle with two 12's. I have not taken any measurements yet.
Off the top of my head, I would do two Fi Q's, since they go low, and would only require about 2500RMS to both drivers, I don't want to weigh my car down with too many batteries, so would not want to go much more than this for the subs, and allows me to put about 600-800RMS up front. I really liked my 12" BTL with 3350RMS total system power in my last car, so why not put a system in this car.
Ideally, I would do a sub behind each seat, firing forwards and a shared port in the center.
Will work on a cardboard template when i have some time, and post results.
In the meantime, I want to know if there are any civics out there with this kind of setup?
Old Jan 20, 2011
MindBomber's Avatar
Live for the Twisties
Re: Rear Seat Enclosure for Subs..
There is a former member who removed his rear seats and replaced it with six 12 inch subs I believe.
Old Jan 21, 2011
electric130's Avatar
oh rice!!!!!!
Old Jan 21, 2011
SpeedDownZone's Avatar
Someone is thinking about wasting there tax return.
Old Jan 22, 2011
What_It_Do's Avatar
I'm not thinking about my tax return at all actually. I've been dreaming about bass!
BTW, I'm Canadian, with not much to claim for taxes..
Old Feb 13, 2011
What_It_Do's Avatar
Well, anyways...
Cardboard template..
Rear seats out.
This will have to go, can weld it back on if I need too.
The hook to the left is about level with the bolts on the right.
Yeah, this will make a good starting surface. Will create a false-floor.
Bottom sheet 40"(W) x 21.5"(D)
Measuring max height.
Won't want to make height (at angle) any more than 28". I'll choose 25" to still be able to see out windows. lol.
Box complete.
Only had to take out both front seats to fit in. Was expecting having to take a door off and center console out, so this is good.
In.
Cut hole to simulate bracket removal.
Seat all the way back and tilted to where I drive.
Some over-hang, which is fine. I only have 8.5" from floor to box though. Which limits me on battery choice. KHC2400 will fit though. Plan on running a single to start. on passenger side. Enough for 3 across the floor is I want. lol
Good height I think.
About even with rear dash.
Was planning on putting battery/s in trunk, but would like to keep most of the weight in cabin instead of the rear of the vehicle, where the amps will be. So instead of sacrificing enclosure volume and shortening the box, I had planned on using 9A31 Deka Intimidator battery, but it's 9.5" tall, so that won't work. Luckily enough for me the Kinetik batteries are relatively short.
Two questions.
The factory battery up front, are there any alternative upgrades which will fit?
I measured the OEM battery and it seems like 9.5"(L)x5.25"(W)x7"(H). That's pretty small.
Where can I get the best H.O alternator for this vehicle?
DC Power which I have dealt with before can do a 180A max @ 130A idle for this vehicle.
PS: Box is 10.13cuft with no displacements and 1" MDF.
Old Feb 13, 2011
MindBomber's Avatar
Wow...
Thats huge...
It's going to feel like riding in an s2000 the cockpit will be so small.
Old Feb 14, 2011
Kennykid2002's Avatar
Kenny the Ricer
Eh, if you're not concerned about the back seats of your car anymore, you can do a copy of what steve meade did with his civic,
2 18" wall behind his front seats
Read up on his build thread
http://www.stevemeadedesigns.com/boa...-update-60907/
Wall build starts on page 4
Old Feb 14, 2011
sl33pyriceboi's Avatar
jeeeeeeeeeze
Old Feb 14, 2011
What_It_Do's Avatar
Thanks, I'm a HUGE SMD follower.
I wanted something which moves more air than a single 12", while not trying to be too heavy either. Two 18's with extra wood/bracing is too heavy IMO. Two 15's would be good...
I drove around last night with the box in the rear, and it didn't feel cramped at all. I think that's due to being able to see over the enclosure, and out all the windows. I'm liking it.
Old Feb 14, 2011
KcRidin09's Avatar
KcRidin09 is an unknown quantity at this point
Go check out CarAudioClassifieds.org its an excellent site to get info on car audio. I would suggest if your going to remove your rear seats, you may as well just wall the Civic. You would def have enough space to run 2 15 Fi's or like the other guy said, 2 18's.
Old Feb 14, 2011
civic01vtec's Avatar
I didn't do it in my civic, but in my previous car, I built a wall from floor to ceiling with (4) 15's. I made it in the local paper for a local competiton. I ripped that out and built another wall to house (1) 15" MTX RFL. I hit 153db's with it. Ran off a Xtant 1000w amp and (2) Nautilus deep cycle batteries. One thing about putting it in the civic, you will have major weight issues.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
Curtchuk
Aug 5, 2015 02:14 PM
