Finished Dual Amp install. quick pics!
Old Jan 10, 2011
7genmarathon's Avatar
7genmarathon is an unknown quantity at this point
I finally finished my dual amp install+speaker replacment and I said I would take pics of it so here they are. I have a total of 30something pics which I will add soon, or make an install guide or something but heres a few of the finished product.
Infinity Perfect 12 VQ woofers wired parallel
MTX 421D Amplifier
Rear speakers TS-D1702R
Jensen power 760 amp mounted on MDF, mounted to rear seat frame.
All in all good install, busted a few plastic panel poppers while replacing the rear deck with the D1702R's All I need to do is set the gain for the sub amp when I get the chance and thats it!
Lemme know what you guys think. Suggestions are welcome!
Old Jan 10, 2011
MindBomber's Avatar
Live for the Twisties
Re: Finished Dual Amp install. quick pics!
Looks good!
I can see you made a new truck panel too!
Old Jan 10, 2011
sl33pyriceboi's Avatar
very nice. good work.
Old Jan 10, 2011
Kennykid2002's Avatar
Kenny the Ricer
Very clean install, how much did the trunk MDF cost total? (including carpeting)
Old Jan 10, 2011
MindBomber's Avatar
It's cheap, all you need is a sheet of MDF, some cheap carpet and a couple hinges. I don't remember what it cost me, but it wasn't much at all.
Old Jan 10, 2011
Kenny the Ricer
I plan to do it, but last I checked, 3/4" MDF was like about $40 at home depot :X
And carpet is expensive too
Old Jan 10, 2011
Yup an MDF trunkbed will put the stock trunkbed to shame!
I got the subs,box,and mono amp given to me free so I basically added on. You can tell the amp has been used(terminal screws and missing rubber screw mount)
Kenny I used 1/2" I can't remember the Lenght, thats all they had but there was plenty left over and seems to do just as well as 3/4"
29.99 Carpet @ crutchfield
~27.99 1/2" MDF at the nearest home depot
~3.00 walmart standard hinges
10.00 3M adhesive spray
I took out some ground slack in the pics and grounded it to a bolt on the frame behind the seatbelt cushions after sanding it down to bare metal. I thought I heard alternator whine earlier today, Im gonna check that soon.
Old Jan 11, 2011
diskreet's Avatar
Looks good!
Agreed... that looks suspiciously similar to a DIY I wrote up a while back (in my sig.) Glad to see other people doing it, too.
Nice install
Old Jan 11, 2011
Nice install
Yup, great DIY by the way diskreet. I had no problems making the trunk. I even touched it up with a router, I wanted to redo the side carpet as well, But it was molded into shape, too cumbersome in my opinion!
Old Jan 12, 2011
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Love the install, I did the same trunk floor replacement but wow that is a tight fit! Cant wait to see more pics, especially how you routed the wiring from the front to the back.
Good install, very clean
Old Jan 12, 2011
diskreet's Avatar
Same reason I didn't do it.
Good job. Enjoy!
Old Jan 12, 2011
Indeed a tight fit. I have maybe half of a fingernails worth of clearance between the sub box and the rear deck speakers. If I ever need to get the subs out I will have to zig zag so the port covers on top of the box so they dont get caught on the magnet<<<Good theft deterrent.
I'll try to add more pics on Friday. Class has started again and I this is the 1st semester im taking all upper division accounting classes
Old Jan 16, 2011
electric130's Avatar
the trunk MDF is worth it! carpet is cheap:
http://www.parts-express.com/pe/show...number=260-767
SimpleUser
Apr 24, 2021 02:54 AM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
