Help
Old Nov 8, 2010
nick187's Avatar
nick187 is an unknown quantity at this point
Help
I own a 2002 civic, its has mods but none by me. the first owner by my book was a retard, everything hes touched is half assed. my problem is when i shut the car off my car all of a sudden makes beeping noises and my spedometer starts bouncing up and down very fast and my odometer starts flashing numbers, trip a/b. it will not stop till i disco the battery. it dose start and drive fine, no power loss or anything.
Old Nov 10, 2010
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: Help
Not a huge expert here, but it sounds like there may be a short somewhere. Did you check the fuse box?
Old Nov 10, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Help
Is there any kind of alarm system on it? Almost sounds like a theft deterrent incorrectly hooked up.
Old Nov 10, 2010
TRIZ's Avatar
Re: Help
Are all the problems associated with the cluster? I'd pull it out and see if everything goes back to normal. At the very least you can see if any wires are ****ed up back there.
