Infinity Component Sys...........
Old Apr 22, 2002
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Ok everyone, I have decided to get the Infinity Component system for the front of my car and I can get a good deal on ebay. The thing I have been wondering about is the rear speakers. I don't want subs because I don't listen to rap and all and I don't feel that I need them. Can I just get another set of 2-way 6x9 speakers for the rear? Thanks you for your help!
Old Apr 22, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
ya you can get a good set of 6x9 that will sound pretty good, if you want to enhance the sound you might be interested in an amp, then possibly dynamatting your trunk. There will be a huge difference in your sound then.
Old Apr 22, 2002
ZSKCivic01's Avatar
Extreme Member
yea, I know I should get some infinity 6x9 speakers in the back, but should they be 2-way or what?
Old Apr 22, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
2 way is fine cause your not gonna use the tweet anyways. just run your rear 6x9's off a small amp and turn the low pass filter on so they only get the lows so you will have a little bass but your highs will just come from up front so your imaging will be better. you won't hear the lows coming from the rear it will just sound like your 6.5's have great low end.
Old Apr 22, 2002
WhiteRabbit's Avatar
<< 2 way is fine cause your not gonna use the tweet anyways. just run your rear 6x9's off a small amp and turn the low pass filter on so they only get the lows so you will have a little bass but your highs will just come from up front so your imaging will be better. you won't hear the lows coming from the rear it will just sound like your 6.5's have great low end. >>
hehe. ben is edumacated [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
"small" is defined by 25 watts RMS or less. cheaper to run off deck power, then build a bandpass crossover.
ben hit it right on the nose, you want to block high frequencies, so as not to destroy imaging, and you want to block low frequencies, as they will only help to distort your sound.
depends on teh woofer, but 80 Hz- 400 Hz is a good starting point to tune to. Id guess that the end result would be about 120-370ish Hz for the final tuning, but that may not be ideal for your low end.
something else you might want to consider is kicker freeair subs. you can get them in 6x9 or 6.5 versions, and coupled with an amp (50x4 all teh way round or something) would compliment each other nicely.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
violentpanda
Sep 7, 2015 11:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
