Advice Amp
Old Oct 2, 2010
xkaosx's Avatar
xkaosx is an unknown quantity at this point
Advice Amp
So I didnt want to get aftermarket stereo and have a 2007 Civic EX Sedan
Obviously I cant get pre outs and have to use High Inputs.
I got an Alpine MRP-F300 4 Channel Amp
It has a built in High Input (4 channel)
I am keeping the stock speakers and got a JL 10" sub
They went and hooked it up and basically used the front head unit speaker outputs and split it into 4 channels at the amp.
If not using separate high level inputs into the amp going to distort the sound at all?
Hope this makes sense :P
Old Oct 2, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: Advice Amp
Uhm....
-scratches head-
What exactly are you trying to ask?
And also, Why are you using a 4chan amp on a subwoofer?
Old Oct 2, 2010
xkaosx's Avatar
Re: Advice Amp
Uhm....
-scratches head-
front channel on amp going to all 4 speakers
rear channel mono to sub
so instead of using 2 sets of rca's because my stock deck doesnt have them they used only the front speaker 2 channel outs from the deck to the amp which they then split into 4 channels into the high input on the amp
Old Oct 2, 2010
Kenny the Ricer
Re: Advice Amp
So let me get this straight,
You have 1 output RCA on stock unit, got that
You plugged in a 4 chan amp,
2 front's you used for speakers, and the 2 rears you bridged for sub?
No it shouldn't distort the sound, as long as the amp is set correctly, however, you might underpower the sub
Old Oct 2, 2010
xkaosx's Avatar
Re: Advice Amp
Haha- i am the worse at trying to explain this
No- no RCA's involved
The alpine amp has a 4 channel high to low converter
Is there a degradation of quality if you split 2 high channels out from the head unit (front left and right speaker wire) into 4 channels going into the amp
Old Oct 2, 2010
Kenny the Ricer
Re: Advice Amp
Ah, I understand what you're saying now
Yes, there will probably be a horrible degration of audio quality
That's like attempting to split a telephone cable into 10 phones
Stock head unit's output is already low, when you try to split it more, the quality will lessen
My suggestion?
Get an aftermarket stereo, plug an amp in correctly with RCA's for your amp to reach full potential
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
