MP3 Sound Quality Problems!
Old Apr 21, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
Ok, I did a little experiment today because I thought there was something fishy about the bass coming from some mp3s:
I listened to the same song on both my real CD and the burned MP3 CD I had of the same song that I downloaded from the net. Beign the same song, the bass produced on the purchased CD was much higher than on the burned CD. Is it because I downloaded the song or is it simply because the file is an MP3? I thought I read something about the compression of MP3 files resulted in a loss of certain frequencies. Is this true? If it is just the fact that it was downloaded and was a bad source, I will just rip the songs from my own CDs at a high bit rate. If all MP3s are like this, I will just get a regular CD player because I it is a waste to buy nice speakers when the source is bad quality. Thanks for any help you can provide.
Old Apr 22, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
Rip them from your own CD's and encode them at a higher quality. Right now I am encoding all of my mp3's at 256kbps, 44kHz, stereo, HQ. I use the LAME codec. That should do the trick. You never know how the mp3's were encoded that you download. Let me know if you have any other questions.
Old Apr 22, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
ya it's better to rip them yourself off of cd's otherwise you'll take a lot of time trying to get them at a good listenable frequency UncleB is right
Old Apr 22, 2002
edy's Avatar
edy
edy is an unknown quantity at this point
I'm guessing that you were probably listening to a low bitrate MP3. Majority of my MP3s are 192kbps, and they sound pretty good.
160 is borderline, 128 is definitely yuck. So you might want to rip your own (fairly easy) or download 192+ mp3s.
To rip 'em, I recomment the LAME codec (for compressing mp3s) that uncleb mentioned and use EAC to rip the tracks.
Go here for more info and where to get these programs:
MP3 encoding and ripping
edy
Old Apr 27, 2002
Bdubb's Avatar
Bdubb is an unknown quantity at this point
mp3s are compressed so you lose a lot of the music frequencies where as a cd plays more
Old Apr 27, 2002
hobbes's Avatar
hobbes is an unknown quantity at this point
I second using the lame codec at either 256 or vbr R3mix settings . (vbr works well with lame)
CDex is a really good ripper/encoder for mp3's. Check out R3mix.net for info on mp3 sound quality.
Old Apr 27, 2002
Bryn's Avatar
Bryn is an unknown quantity at this point
no reason to get MP3's at more than 192 kbps because that is what REAL CD's are at? You can't rip a CD any higher than what is at at. It's like trying to get 400HP out of our engines, can't do it. Anyway, you will lose some frequencies because that is how MP3's work. It eliminates sounds that you cannot hear or that speakers do not reproduce well. If you have a nice system, you might lose some of the REALLY low frequencies that you FEEL! I never notice that to be the case when I burn MP3 cd's though. Hope this helps.
Old Apr 29, 2002
hobbes's Avatar
256kbit/s is CD quality...
(with Lame anyway)
MP3 info
MamaBear2015
May 3, 2015 02:17 PM
bsmiley
Apr 27, 2015 01:27 PM
BumpinCivic2k1
Nov 18, 2001 04:44 PM
ImmortalEX
Nov 15, 2001 06:29 PM
