green key flashes on instrument panel
Old Jun 10, 2010
okie44e's Avatar
okie44e is an unknown quantity at this point
at times when i try and start my 2001 civic lx, the green key on the instrument panel flashes and it will not do anything, all lights and everything elseworks but the starter will not engage or make any other noises, by turning the key on and off a few times sometimes then it will engage and start. its the orginal key. though it might be the nutural safety switch but moving the shifter from netural to park does not help. the starter or nothing will engage. any suggestions
Old Jun 10, 2010
lordhelmet's Avatar
Re: green key flashes on instrument panel
Something is screwed up with the key fob or the ignition.
Old Jun 10, 2010
yeah its either the key went bad or the immobilizer system itself. if it cannot read the chip in your key, it will shut off ignition and fuel pump. check for loose battery connection too. if you have a spare key, try that one too. do not have any other electronic type devices (or other chipped keys) around the honda key when starting the car.
Old Jun 10, 2010
lordhelmet's Avatar
A bad key fob would still let the motor turn over. I think the ignition is the culprit.
Old Jun 10, 2010
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Try another key to eliminate it being the chip inside. Maybe someone did a starter install and added a bypass. Then removed it....partially....before selling it to you.
CarStuff
Dec 6, 2020 12:52 PM
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
01civyv3
Jun 2, 2015 05:21 AM
beveragemp
May 25, 2015 07:11 PM
davidarenberg
May 16, 2015 08:45 AM
