Honda Civic blower fan problem
Old Jun 6, 2010
coolcat.vboy's Avatar
coolcat.vboy is an unknown quantity at this point
No Air Blowing out of vents (a/c, heater ...).
Car is a honda civic EX 2002 4cylinder.
1. Checked the fuses under the hood and under the kick panel on the driver side. Looked good to the naked eye.
Took it to the mechanic
1. He, replaced the blower motor with new one. No use. I confirmed this myself by jumping the old motor to the 12v battery. It spins.
2. He, replaced the blower resistor with new one. No use.
3. He said its the switch assembly and its a dealer part. Order the part oneline.
Took the entire center panel by myself and replaced the heater assembly with new one.
Still no use.
I going to buy a multi meter (after I post this) and check the voltages at different points my self. but pretty much we replaced all the parts in the system to no effect right.
One thing I observed is when I turn the key to the on positions, I hear the fan starts for like 1 sec and then stops...
Is there is some kind of relay that closes and lets its run.. that I should check for...
How do I proceed. Please help. I have no fan for a month now and its getty really hot here.
Old Jun 6, 2010
CraigW's Avatar
Re: Honda Civic blower fan problem
It sure sounds like a problem with your "transistor" it is a solid state replacement for the blower resistors used in earlier days.
I remember someone said the fan would run for a second then stop iirc.
There is what I think to be a 114 degree C thermal cut-off that is used on the module that opens up. You can solder a new TCO in it's place.
You might want to see what he replaced a new transistor unit would have solved the problem if the TCO were open on the old one.
Also make sure your cabin filter is not clogged, no air flow can cause this failure.
Old Jun 8, 2010
mcslick12's Avatar
mcslick12 is an unknown quantity at this point
I doubt if this is the problem but I was having a problem with my AC not blowing and it was actually my cabin air filters were clogged(located behind the glove box) but when I turned it up all the way I could at least feel something.
Old May 15, 2011
dssgod's Avatar
dssgod is an unknown quantity at this point
Have you figured out what it was yet? It seems this question has been posted numerous times but not a single solution yet.
Old May 15, 2011
dssgod's Avatar
...back again, started the diagnosis and found the customer was missing the blower relay completely along with a few fuses. I took one off an accord to test it out and it works perfectly.
Civicman92296
Apr 23, 2015 09:22 PM
paulnguyen
Apr 20, 2015 01:33 PM
jessicakaybby
Apr 20, 2015 12:11 PM
prowl
Apr 18, 2015 07:50 PM
dooner24
Apr 14, 2015 07:51 PM
