best trunk
x-factor
best trunk
imtrying to get ideas for my trunk set up i have 2 12's in seperate boxes and 3 amps ne 1 have an idea or pix would help alot thanx
sorry if its in the wrong section.
for alot of showy ideas, check out the members rides at www.sounddomain.com!
if it were my creative install, id relocate teh spare tire to under the car, raise the floor till i had teh proper airspace, then bolt the 12's, with the spiders facing up, on either side of the trunk near the strut towers. then get creative with neons that flash to the beat [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
the amps would be tough.... maybe mount two on 3/8 to 1/2 inch plexi panels, then put those on four plexy cylindrical legs, the front two of which are shorter than teh back two, so the amp is facing the viewer who opens the trunk. then you place two small neons behind, out of view....the plexi catches the light so it looks like yoru amps are floating on a (insert color name here) slab!
the third will be mounted to the ceiling of the trunk, and will flip down cause its attatched to a linear actuator (this is getting expensive!) tho i probably would just install it like the other two, forming a carrot shape in the trunk (amps arranges liek this: "^")
so it would look kinda like this:
(cabin)
O_____O
___[ ]___ (top view)
[ ]____[ ]
(liscence plate)
where:
O is a sub
[ ] is an amp
edit: fixed ascii "pic" also, you would basically lose your trunk, but heck, i never use mine anyways, you really dont need it [IMG]i/expressions/face-icon-small-wink.gif[/IMG] its what teh back seat is for! [IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
(cabin)
O_____O
[ ]____[ ]
(liscence plate)
where:
O is a sub
[ ] is an amp
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
Skunkone
Sep 24, 2015 04:38 PM
