n00b alert... :/
Old Apr 22, 2010
luckyanniem's Avatar
luckyanniem is an unknown quantity at this point
n00b alert... :/
this is what's in the car right now:
it's a little older, alpine (not sure on model).
if i want this:
http://signature.crutchfield.com/s_1...tp=20217&avf=Y
Will I only need this:
http://www.scosche.com/products/productID/1925
And just to make it a little more confusing... I found somewhere a single din would work if i just popped out the middle part. I'm assuming that's what's holding the Alpine stereo in there, so can I pop out the middle of it and be good to go?
Again, sorry for my lack of terminology. But I'm pretty sure I was as clear as possible, lol.
Old Apr 22, 2010
04 Honda Civic's Avatar
Re: n00b alert... :/
It will look like **** if you dont buy the trim piece. You will also need a harness that connects to your OEM radio harness, so you dont have to cut it off.
Old Apr 23, 2010
ok. i didn't understand if the trim from the double din AND the single din (what i'm assuming was in there with the alpine) are the same trim in the outside sense. so then popping out the middle wouldn't work.
and is a wire harness different for single din vs double din? as in a different wire harness than what's in there?
Old Apr 23, 2010
keep the old alpine! those are awesome decks. but if you must switch to the screen, get the 2005 civic SE (special edition) oem double din trim piece that replaces the one you have now.
Old Apr 23, 2010
01VicEx's Avatar
01VicEx is an unknown quantity at this point
Just a word of caution, if you select "Outfit You Car" on Crutchfield it says this headunit will not fit. Although, Crutchfield usually does this if some modification is required for the unit to work right.
Old Apr 24, 2010
wallydude03's Avatar
wallydude03 will become famous soon enough
You dont absolutely need the double din plastic, but without it there will be a gap around the stereo. Also crutchfield said that my stereo that i have right now would not fit in my car but it did, i had to drill new holes in my cars stereo bracket, because otherwise the stereo was sitting to far back and it didnt look right. I really wish i had taken better pics during my install, but heres what i got. Maybe it will help u out.
With out the double din plastic:
With the plastic:
Old Apr 24, 2010
it was never a trim or no trim question... just WHICH to get lol.
crutchfield said it won't fit but pioneer's website says it will, and i've found lots of 7th gen's with the particular one i want... i just know my knowledge only goes so far (obviously) and i don't want to buy everything and hand someone a headache who tries to install it.
is the wire harness for the alpine that's in there different from the wire harness i would need for the new pioneer one i want?
Old Apr 24, 2010
yes each brand has a different harness plug in the back
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
TheSmuggler
Engine Swaps
31
Feb 28, 2005 10:59 PM
