speaker distortion when turned up.. help!
Old Mar 11, 2010
2k2Black's Avatar
2k2Black is an unknown quantity at this point
i have some polk audio 6.5 speakers in my doors and a aftermarket deck.. when i turn the volume up the voice cuts out when the bass hits and it makes a crackle kinda noise.. the speakers are fine but i think i need a crossover or maybe just a amp with one built in it? any suggestions i want the distortion gone but i want to be able to turn it up.
Old Mar 11, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: speaker distortion when turned up.. help!
uh, do you have them wired up correctly? as in make sure you dont have positive going to negative and negative going to positive. also, you can't turn it up ridiculously loud and expect it to be perfect with just a deck and some 2ways or what not.
Old Mar 13, 2010
electric130's Avatar
you need an amp.
Old Mar 13, 2010
2k2Black's Avatar
ya i have them hooked up right.. and ok i think ill try out a amp thanks for the help.
Old Mar 29, 2010
Crutcher's Avatar
Crutcher is an unknown quantity at this point
try turning down the bass and turning up the treble on your system
Old Mar 30, 2010
SPUNKYcivy01's Avatar
SPUNKYcivy01 is an unknown quantity at this point
Originally Posted by electric130
you need an amp.
X2
Just because you have aftermarket speakers and head unit DOES NOT mean your speakers are powered enough. Your head unit probably puts out about 50 watts x 4= 12.5 watts per speaker
Check the limits for your speakers and find an amp that matches them. Otherwise, you will always get distortion.
Any other questions let me or ^ know
mohawkboom
67
Aug 25, 2015 12:28 AM
SLeePeR012
Jan 7, 2002 12:24 AM
djaber
Jan 4, 2002 06:23 PM
AFlyer
Dec 27, 2001 06:16 PM
ademarco6
Nov 16, 2001 10:19 PM
